projection woes
Matthew Perry
mtperry78 at SBCGLOBAL.NET
Tue Jan 25 13:00:22 EST 2005
I knew there must have been *some* reason. This is one
of those issues that constantly trips me up since OGC
SRS uses "EPSG"... It's easy to get into the habit of
typing it all caps.
- matt
--- Ed McNierney <ed at TOPOZONE.COM> wrote:
> Matt -
> It's not a matter of MapServer being picky - the
> "epsg" is actually a
> filename, and on case-sensitive operating systems,
> case matters.
> - Ed
> Ed McNierney
> President and Chief Mapmaker
> TopoZone.com / Maps a la carte, Inc.
> 73 Princeton Street, Suite 305
> North Chelmsford, MA 01863
> ed at topozone.com
> (978) 251-4242
> -----Original Message-----
> From: UMN MapServer Users List
> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
> Behalf Of Matthew Perry
> Sent: Tuesday, January 25, 2005 12:32 PM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] projection woes
> You might try using "init=epsg:26717" instead of
> "init=EPSG:26717". I
> know that some versions of mapserver are picky about
> this
> capitalization.
> Other than that, your mapfile looks like it should
> work.
> Matt Perry
> Humboldt State University
> --- Mark Adams <markadams at CUESTASYS.COM> wrote:
> > I've included my map file below.
> > Regarding Stephen Woodbridge's response, the data
> in all files is in
> > zone 17, the only difference is the datum; and I
> can confirm that the
> > data really is there. As I indicated, if I don't
> include the
> > projection block on the layer the data shows, just
> shifted because of
> > the different datum. (Also working with it in
> ArcMap etc.)
> > If it's likely that that I either don't have the
> right files, or for
> > some reason they aren't being found, how can I
> test this, and how do I
> > know which files I need? Incidentally, I installed
> proj.4 from the
> > proj446_win32_bin.zip distribution; and I'm
> running on Win2000, IIS 5.
> > -----map file------
> > # Start of map file
> > MAP
> > NAME "MVCA_GeoPortal"
> > STATUS ON
> > EXTENT 433350 4813769 546722 4889572
> > SIZE 682 456
> > #SIZE 674 474
> > SHAPEPATH "..\Data\Shapefiles"
> > #TEMPLATEPATTERN "MVCA_GeoPortal"
> > SYMBOLSET "GeoPortal.symbols"
> > #fonset added AD 13-Jul-04
> > FONTSET "GeoPortal.fonts"
> > #IMAGETYPE PNG
> > #IMAGETYPE swf
> > #IMAGETYPE png24bit
> > IMAGETYPE gif
> > #IMAGECOLOR 255 255 255
> > UNITS METERS
> > OUTPUTFORMAT
> > NAME gif
> > DRIVER "GD/GIF"
> > MIMETYPE "image/gif"
> > IMAGEMODE PC256
> > EXTENSION "gif"
> > TRANSPARENT ON
> > END
> > OUTPUTFORMAT
> > NAME png24bit
> > DRIVER "GD/PNG"
> > MIMETYPE "image/png"
> > IMAGEMODE rgb
> > FORMATOPTION "INTERLACE=OFF"
> > END
> > OUTPUTFORMAT
> > NAME swf
> > DRIVER "SWF"
> > MIMETYPE "application/x-shockwave-flash"
> > EXTENSION "swf"
> > IMAGEMODE PC256
> > FORMATOPTION "OUTPUT_MOVIE=SINGLE"
> > END
> > # Start of web interface definition (including
> WMS enabling
> > metadata)
> > WEB
> > #MINSCALE 500
> > MAXSCALE 1550000
> > IMAGEPATH "C:\Inetpub\wwwroot\tmp\"
> > IMAGEURL "/tmp/"
> > HEADER "templates/header.html"
> > FOOTER "templates/footer.html"
> > TEMPLATE "set in index.html"
> > METADATA
> > "WMS_TITLE" "MVCA MapServer GeoPortal"
> > "WMS_ABSTRACT" "This is MapServer
> > application using data from Maitland Valley
> Conservation Authority."
> > "WMS_ACCESSCONSTRAINTS" "none"
> > "WMS_ONLINERESOURCE"
"http://navigator/cgi-bin/mapserv.exe?map=C:\Inetpub\wwwroot\mapserver_d
> emos\MVCA_GeoPortal\config\MVCA_GeoPortal.map&"
> > "WMS_SRS" "EPSG:26717"
> > END
> > END
> > # Start of reference map
> > REFERENCE
> > IMAGE "reference.png"
> > EXTENT 433350 4813769 534792 4889572
> > SIZE 168 118
> > #SIZE 84 59
> > STATUS ON
> > #COLOR 175 175 208
> > COLOR -1 -1 -1
> > OUTLINECOLOR 175 175 208
> > MINBOXSIZE 5
> > MAXBOXSIZE 500
> > MARKER "star"
> > MARKERSIZE 8
> > END
> > # Projection definition, consult the PROJ.4
> documentation for
> > parameter discussion
> > PROJECTION
> > # proj=utm
> > # ellps=GRS80
> > # zone=15
> > # north
> > # no_defs
> > # OR:
> > # init=epsg:26915
> > "init=EPSG:26717"
> > END
> > # Start of legend
> > LEGEND
> > STATUS ON
> > KEYSIZE 18 12
> > LABEL
> > TYPE BITMAP
> > SIZE MEDIUM
> > COLOR 0 0 89
> > END
> > TEMPLATE "legend.html"
> > END
> > # Start of scalebar
> > SCALEBAR
> > STATUS ON
> > POSITION LR
> > POSTLABELCACHE TRUE
> > #BACKGROUNDCOLOR 166 202 240
> > BACKGROUNDCOLOR 254 219 67
> > COLOR 0 0 156
> > OUTLINECOLOR 166 202 240
> > TRANSPARENT ON
> > #IMAGECOLOR 0 0 0
> > UNITS KILOMETERS
> > INTERVALS 4
> > SIZE 200 8
> > STYLE 0
> > LABEL
=== message truncated ===
