SWIG mapscript request/bug?
Sean Gillies
sgillies at FRII.COM
Tue Jan 25 17:47:30 EST 2005
On Jan 25, 2005, at 3:28 PM, Ryan, Adam wrote:
> Hi. I'd like to make a request. In using python mapscript I find
> that a
> layer's index property is unchanged after using map.moveLayerUp/Down.
> Shouldn't the index values of the two layers that are swapped be
> swapped
> themselves?
> Is this a bug that I should report?
> Cheers,
> Adam
Adam,
A MapServer mapObj has an array of layerObjs and also an array of
indexes of these layerObjs in drawing order. It is this second array
that is modified by moveLayerUp/Down. Same situation for the other
mapscripts including PHP. It's not a bug, just the way that MapServer
is designed.
cheers,
Sean
Sean Gillies
sgillies at frii dot com
http://users.frii.com/sgillies
