SWIG mapscript request/bug?
Ryan, Adam
ARyan at CO.LINN.OR.US
Tue Jan 25 18:05:11 EST 2005
> -----Original Message-----
> From: Sean Gillies [mailto:sgillies at frii.com]
> Sent: Tuesday, January 25, 2005 2:48 PM
> To: Ryan, Adam
> Cc: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: SWIG mapscript request/bug?
> On Jan 25, 2005, at 3:28 PM, Ryan, Adam wrote:
> > Hi. I'd like to make a request. In using python mapscript I find
> > that a
> > layer's index property is unchanged after using
> map.moveLayerUp/Down.
> > Shouldn't the index values of the two layers that are swapped be
> > swapped
> > themselves?
> > Is this a bug that I should report?
> > Cheers,
> > Adam
> Adam,
> A MapServer mapObj has an array of layerObjs and also an array of
> indexes of these layerObjs in drawing order. It is this second array
> that is modified by moveLayerUp/Down. Same situation for the other
> mapscripts including PHP. It's not a bug, just the way that
> MapServer
> is designed.
> cheers,
> Sean
> Sean Gillies
> sgillies at frii dot com
> http://users.frii.com/sgillies
Hey Sean, thanks for the reply.
Maybe you can lend a suggestion. I want to manipulate the draw order using
a list of layer names from the client. I'd like to do this:
curI = 0
for layerName in layerList:
layerO = mapO.getLayerByName(layerName)
while layerO.index > curI: mapO.moveLayerUp( layerO.index )
curI += 1
The problem, if I understand it, is that the layer index is indeed being
moved up in the drawing order, but the index values don't change. Thus, my
while statement runs forever.
I see there are get/setLayersDrawingOrder methods but how much work is it to
set them up?
Thanks again,
Adam
