MapServer and Oracle Spatial
Lyndon Tiu
ltiu at ALUMNI.SFU.CA
Tue Jan 25 19:05:48 EST 2005
Hello,
I have:
1) Mapserver 4.4.1 on Linux compiled with oraclespatial support.
2) Oracle Spatial 10g on Solaris.
3) Tnsnames are configured properly and sqlplus from the Linux command
line can connect to Oracle database on Solaris box.
4) Listener and database have both been started and are both running on
Solaris box.
5) mapserver map file:
LAYER
NAME "oggma"
CONNECTIONTYPE oraclespatial
CONNECTION "user/pass at orasptl"
DATA "GEOM FROM OGGMA USING SRID NULL"
STATUS ON
TYPE POLYGON
CLASS
STYLE
OUTLINECOLOR 0 0 0
COLOR 225 225 185
END
END
PROJECTION
"init=epsg:42102"
END
END
The connect string:
user/pass at ora10g works fine from the command line and from Oracle
Enterprise Manager so I know tnsnames is configured properly.
Also, the table OGGMA and data are loaded and I can do a select * from
OGGMA and data would come back fine.
6) Pointing a web browser at mapserver produces the following error:
<?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
<!DOCTYPE ServiceExceptionReport SYSTEM
"http://schemas.opengeospatial.net/wms/1.1.1/exception_1_1_1.dtd">
<ServiceExceptionReport version="1.1.1">
<ServiceException>
msDrawMap(): Image handling error. Failed to draw layer named
'ogma'.
msOracleSpatialLayerOpen(): OracleSpatial error. Cannot create OCI
Handlers. Connection failure. Check the connection string. Error: .
</ServiceException>
</ServiceExceptionReport>
Can someone help me with this issue?
Thank you for any tips and suggestions.
Lyndon Tiu
