Example Maps
Ingo Paulsen
paulseni at UNI-DUESSELDORF.DE
Wed Jan 26 03:53:48 PST 2005
hm, I'm not sure about your .tif problem.
file
in /var/www/html/tmp/11067393996391.png (with the US States in yellow)
and not a .tif file.
Does including dl("php_mapscript.so"); in your usa1.phtml file work
properly?
My mapserv config is:
MapServer version 4.4.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=PDF SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
Best regards
Ingo
> I have the .tif and shape files and the results (.png) files in the
> same directory.
> The only thing is that the IMAGEURL path I put is as in the example:
> not with the complete path. I will try it putting all the path, but I
> am not very sure it will work.
> I suspect that it doesn't find the correct files that mapserver needs
> to process .tiff files. I compiled it as you seee with gdal, but I am
> not very sure if he really can get it. I don't know if he can really
> manage those type of files.
More information about the MapServer-users
