Example Maps
Jose Luis Gonzalez
joseluismapserver at YAHOO.ES
Wed Jan 26 06:03:09 EST 2005
I have the .tif and shape files and the results (.png) files in the same directory.
The only thing is that the IMAGEURL path I put is as in the example: not with the complete path. I will try it putting all the path, but I am not very sure it will work.
I suspect that it doesn't find the correct files that mapserver needs to process .tiff files. I compiled it as you seee with gdal, but I am not very sure if he really can get it. I don't know if he can really manage those type of files.
Thank you
Jose Luis
Ingo Paulsen <paulseni at UNI-DUESSELDORF.DE> wrote:
Hello,
I fixed the problem by replacing the IMAGEURL path with IMAGEPATH entry.
Did you take a look in your /var/www/html/tmp/ directory? Are there any
dynamically created .png files?
WEB
IMAGEPATH "/var/www/html/tmp/"
IMAGEURL "/var/www/html/tmp/"
END
I suppose you have installed the shapefiles in /var/www/html/data.
Best regards
Ingo
> I am also using the examples, and I want to make the usa.map work but
> it doesn't.
> Does it work for you?
> Did you see anything wrong?
> I am working with:
> MapServer version 4.4.0 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER INPUT=EPPL7
> INPUT=GDAL INPUT=SHAPEFILE
> So I think that if I have gdal it should recognize .tif files and
> should work. But it doesn't
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050126/79f007d9/attachment.html
