Example Maps
Ingo Paulsen
paulseni at UNI-DUESSELDORF.DE
Wed Jan 26 04:52:45 EST 2005
Hello,
I fixed the problem by replacing the IMAGEURL path with IMAGEPATH entry.
Did you take a look in your /var/www/html/tmp/ directory? Are there any
dynamically created .png files?
WEB
IMAGEPATH "/var/www/html/tmp/"
IMAGEURL "/var/www/html/tmp/"
END
I suppose you have installed the shapefiles in /var/www/html/data.
Best regards
Ingo
> I am also using the examples, and I want to make the usa.map work but
> it doesn't.
> Does it work for you?
> Did you see anything wrong?
> I am working with:
> MapServer version 4.4.0 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER INPUT=EPPL7
> INPUT=GDAL INPUT=SHAPEFILE
> So I think that if I have gdal it should recognize .tif files and
> should work. But it doesn't
