SWIG mapscript request/bug? - WORKAROUND
Sean Gillies
sgillies at FRII.COM
Wed Jan 26 09:05:05 EST 2005
On Jan 25, 2005, at 5:30 PM, Ryan, Adam wrote:
> And the workaround is...
> When you're reordering layers AND you want to do a drawQuery(),
> reorder the
> layers and then save the map file and then load it again and then
> drawQuery(). Ugly.
> Adam
Adam,
Brutal, I agree. But since you are using mapscript you do have the
option of programming your own query map. I don't think msDrawQueryMap
does anything that you can't script yourself.
Steve Lime has been considering an overhaul of the query map but I am
neither sure of the status nor sure that he is looking at your issue.
cheers,
Sean
Sean Gillies
sgillies at frii dot com
http://users.frii.com/sgillies
