SWIG mapscript request/bug? - WORKAROUND
Lowell Filak
lfilak at MEDINACO.ORG
Wed Jan 26 10:04:08 EST 2005
The following message was sent by Sean Gillies <sgillies at FRII.COM> on
Wed, 26 Jan 2005 07:05:05 -0700.
> On Jan 25, 2005, at 5:30 PM, Ryan, Adam wrote:
> > And the workaround is...
> > When you're reordering layers AND you want to do a drawQuery(),
> > reorder the
> > layers and then save the map file and then load it again and then
> > drawQuery(). Ugly.
> > Adam
> Adam,
> Brutal, I agree. But since you are using mapscript you do have the
> option of programming your own query map. I don't think msDrawQueryMap
> does anything that you can't script yourself.
> Steve Lime has been considering an overhaul of the query map but I am
> neither sure of the status nor sure that he is looking at your issue.
Adam,
I agree with Sean as we have never used the queryMapObj here, but rather
just another mapObj. There have been a few issues that have come up
pertaining to the queryMapObj and for a spell I thought it should go the
way of the DBFInfo object, at least as far as the documentation goes for
mapscript.
Lowell
