Showing some text in a layer
Julien-Samuel Lacroix
jlacroix at DMSOLUTIONS.CA
Tue Jan 25 09:18:01 EST 2005
I'm far from a PostGIS expert, but I notice 2 problems in your layer.
1. Your layer type is LINE, but in your table you seem to have a POINT
layer. Am I right? So if you want to show points you should use
TYPE POINT
or if you only want to show the labels, you should use:
TYPE ANNOTATION
2. You don't have any style in your class. For LINE and POINT types, you
should have a STYLE in your class.
Thanks
Julien
Aaron Craig wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> In my mapfile, I've defined a layer:
> LAYER
> TYPE LINE
> STATUS DEFAULT
> NAME "museum_label"
> CONNECTION 'user=postgres dbname=postgis_sardegna'
> CONNECTIONTYPE POSTGIS
> DATA 'point_geom from museum'
> LABELITEM "name"
> CLASS
> ~ LABEL
> ~ COLOR 0 0 0
> ~ TYPE TRUETYPE
> ~ FONT arial
> ~ SIZE 10
> ~ ANTIALIAS TRUE
> ~ POSITION CC
> ~ PARTIALS FALSE
> ~ MINDISTANCE 10
> ~ BUFFER 1
> END # end of label
> END
> END
> The museum table looks like:
> postgis_sardegna=# \d museum
> ~ Table "public.museum"
> ~ Column | Type | Modifiers
> ~ id | integer |
> ~ name | character varying(255) |
> ~ xdb_id | integer |
> ~ point_geom | geometry |
> Check constraints:
> ~ "enforce_srid_point_geom" CHECK (srid(point_geom) = -1)
> ~ "enforce_geotype_point_geom" CHECK (geometrytype(point_geom) =
> 'POINT'::text OR point_geom IS NULL)
> But the layer does not display. In the mapfile, it is the last layer to
> be declared, so it should be rendered last (on top), correct?
> Another layer that shows labels does work. The syntax for the layer is
> the same, leading me to believe that my mapfile syntax is ok. The
> working layer's underlying table's geometry column is MULTIPOLYGON
> instead of POINT. Could that be the problem?
> Thanks.
> Aaron Craig
> mercutio at pobox.com
> Get Firefox!
> http://www.spreadfirefox.com/?q=affiliates&id=0&t=1
> I am but mad north-northwest: when the wind is southerly I know a hawk
> from a handsaw. --Hamlet, II:2
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.2.4 (GNU/Linux)
> Comment: Using GnuPG with Thunderbird - http://enigmail.mozdev.org
> iD8DBQFB9iS7oyEQRcU83p4RAjIaAKCHW/NKMTrRueEz3NGBBBxSTqqX/ACcCGYi
> z4jh9xXhwvQyLvbPB4AC2gQ=
> =DhU0
> -----END PGP SIGNATURE-----
Julien-Samuel Lacroix jlacroix at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
