Showing some text in a layer
    Aaron Craig
    mercutio at POBOX.COM
    Tue Jan 25 02:51:39 PST 2005
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
In my mapfile, I've defined a layer:
LAYER
        TYPE LINE
        STATUS DEFAULT
        NAME "museum_label"
        CONNECTION 'user=postgres dbname=postgis_sardegna'
        CONNECTIONTYPE POSTGIS
        DATA 'point_geom from museum'
        LABELITEM "name"
        CLASS
~               LABEL
~                       COLOR 0 0 0
~                       TYPE TRUETYPE
~                       FONT arial
~                       SIZE 10
~                       ANTIALIAS TRUE
~                       POSITION CC
~                       PARTIALS FALSE
~                       MINDISTANCE 10
~                       BUFFER 1
                END # end of label
        END
END
The museum table looks like:
postgis_sardegna=# \d museum
~              Table "public.museum"
~   Column   |          Type          | Modifiers
~ id         | integer                |
~ name       | character varying(255) |
~ xdb_id     | integer                |
~ point_geom | geometry               |
Check constraints:
~    "enforce_srid_point_geom" CHECK (srid(point_geom) = -1)
~    "enforce_geotype_point_geom" CHECK (geometrytype(point_geom) =
'POINT'::text OR point_geom IS NULL)
But the layer does not display.  In the mapfile, it is the last layer to
be declared, so it should be rendered last (on top), correct?
Another layer that shows labels does work.  The syntax for the layer is
the same, leading me to believe that my mapfile syntax is ok.  The
working layer's underlying table's geometry column is MULTIPOLYGON
instead of POINT.  Could that be the problem?
Thanks.
Aaron Craig
mercutio at pobox.com
Get Firefox!
http://www.spreadfirefox.com/?q=affiliates&id=0&t=1
I am but mad north-northwest: when the wind is southerly I know a hawk
from a handsaw. --Hamlet, II:2
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.4 (GNU/Linux)
Comment: Using GnuPG with Thunderbird - http://enigmail.mozdev.org
iD8DBQFB9iS7oyEQRcU83p4RAjIaAKCHW/NKMTrRueEz3NGBBBxSTqqX/ACcCGYi
z4jh9xXhwvQyLvbPB4AC2gQ=
=DhU0
-----END PGP SIGNATURE-----
More information about the MapServer-users
