installation problems [was Re: Example Maps]
Julien-Samuel Lacroix
jlacroix at DMSOLUTIONS.CA
Mon Jan 31 10:51:44 EST 2005
Hello,
Did you succeed to compile as a CGI. Nothing is missing in your
configuration. You may want to add
--with-regex=system
But this does not prevent the CGI to compile. The cgi executable is
supposed to be in sapi/cgi/
if you do a simle test.php page:
<?php
dl("php_mapscript_40.so");
phpinfo();
Does the phpinfo page show the loaded mapscript extension?
Julien
Nicole Faust wrote:
> Hello,
> This are the options that I used, to configure PHP:
> ./configure --with-gd=/home/n_faust/software/projekt
> --with-pgsql=/home/n_faust/software/projekt --enable-force-cgi-redirect
> --enable-fastcgi --prefix=/home/n_faust/software/projekt
> Are there any options missing?
> Regards,
> Nicole
> On Tue, 25 Jan 2005, Julien-Samuel Lacroix wrote:
>>Hi,
>>Check the installation instruction for your OS:
>>http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?PHPMapScript
>>Normally adding --enable-force-cgi-redirect to your configure command
>>should do the job.
Julien-Samuel Lacroix jlacroix at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
