PHP-Mapserver query result
Palanisamy, Giri
palanisamyg at ORNL.GOV
Thu Jan 27 09:22:14 EST 2005
Kevin,
Thanks for the suggestion, but I have almost customized my demo
application with the help of GMap sample app, and this is the final part
I need to find out!
Giri
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Kevin Grootendorst
Sent: Thursday, January 27, 2005 9:14 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] PHP-Mapserver query result
Giri,
I don't know exactly how to solve your problem, but have you tried using
MapLab to create an application? By default, querying a MapLab
application
will launch a separate window with the query results.
Maybe that might help?
Kevin
On Thu, 27 Jan 2005 09:10:00 -0500, Palanisamy, Giri
<palanisamyg at ORNL.GOV>
wrote:
>Hi List,
>Sorry for this repeated postings, but I still could not figure out a
>solution, I would really appreciate if any one can give me some idea
for
>the problem discussed below.
>I just got the php-mapscript (rosa) GMap sample application running, I
>would like to display the query results in a new page, the sample
>application does it in the same page (when I press the "info" button
and
>click some points on the map it displays the city names in the same
>page)? I could achieve this in JBox-mapscript application by setting
the
>TEMPLATE in the class object in the .map file as
>LAYER
> NAME fluxnet_ll_use
> METADATA
> "DESCRIPTION" "Sites"
> "RESULT_FIELDS" "SITE_LABEL NETWORK COUNTRY STATUS IGBPCLSS CLIMATE
>LONG LAT "
> END
> GROUP MODIS
> TYPE POINT
> DATA f264
> STATUS DEFAULT
> PROJECTION
> "proj=longlat"
> "ellps=GRS80"
> "no_defs"
> END
> CLASS
> NAME 'FLUXNET Sites'
> COLOR 0 0 255
> SYMBOL 'triangle'
> SIZE 10
> TEMPLATE "fluxsites.phtml"
> END
> TOLERANCE 5
>END
>I would really appreciate if anyone can tell me how to do this with the
>php-mapscript (rosa)?
>Thanks
>Giri
