Example Maps
Nicole Faust
n_faust at INFORMATIK.UNI-KL.DE
Thu Jan 27 09:46:41 EST 2005
Hello,
> I am also using the examples, and I want to make the usa.map work but it doesn't.
> Does it work for you?
> Did you see anything wrong?
> I am working with:
> MapServer version 4.4.0 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER INPUT=EPPL7 INPUT=GDAL INPUT=SHAPEFILE
I have still problems display the map, too.
I work with:
MapServer version 4.2.3 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
I changed the following path (in the WEB section) in the .MAP file
(but it doesn't work anyway):
IMAGEPATH "/home/n_faust/software/projekt/htdocs/karten/tmp/"
IMAGEURL "/karten/tmp"
htdocs is the DocumentRoot of Apache and karten a subdirectory where
I stored the .SHP, .SHX and .MAP files. In the tmp subdirectory the
mapserver stores the generated image files. This works for .PHTML files
but not for .MAP files and I don't know why.
Regards,
Nicole
