Problem with Mapscript + PostGIS
Abe Gillespie
agillesp at VT.EDU
Thu Jan 27 14:48:44 EST 2005
You were absolutely right! The problem was an old libmap.dll.
Thanks as always.
-Abe
On Jan 27, 2005, at 1:53 PM, Sean Gillies wrote:
> On Jan 27, 2005, at 12:00 PM, Abe Gillespie wrote:
>> --Apple-Mail-24--303801657
>> Content-Transfer-Encoding: quoted-printable
>> Content-Type: text/plain;
>> charset=US-ASCII;
>> format=flowed
>> I'm compiling everything on Windows. MapServer CGI compiles fine
>> with=20=
>> "mapserv -v" giving:
>> MapServer version 4.4.1 OUTPUT=3DGIF OUTPUT=3DPNG OUTPUT=3DJPEG =
>> OUTPUT=3DWBMP=20
>> SUPPORTS=3DPROJ SUPPORTS=3DFREETYPE SUPPORTS=3DWMS_SERVER
>> INPUT=3DPOSTGIS=20=
>> INPUT=3DOGR INPUT=3DGDAL INPUT=3DSHAPEFILE DEBUG=3DMSDEBUG=00
>> I also don't have any problem compiling the C# version of Mapscript.
>> =20
>> But when I try to access a PostGIS layer the logs tell me I don't
>> have=20=
>> PostGIS support available. Here's the error:
>> Thu Jan 27 13:18:39 2005 - msPOSTGISLayerOpen(): Query error.=20
>> msPOSTGISLayerOpen called but unimplemented! (mapserver not
>> compiled=20
>> with postgis support)
>> Thu Jan 27 13:18:39 2005 - msDrawMap(): Image handling error. Failed
>> to=20=
>> draw layer named 'Roads'.
>> I know C# Mapscript is brand new ... so help however you can. BTW -
>> is=20=
>> there a way to do the same as "mapserv -v" in Mapscript? Something=20
>> like mapObj::version I'd imagine.
>> Thanks.
>> -Abe=
> There is mapscript::MS_VERSION, but it is only the version string. I
> like the idea, you should enter it in Bugzilla as a mapscript
> enhancement.
> Without the benefit of any other information, I guess that you have
> some DLL mixup. Some DLL without libpq is getting in the way.
> cheers,
> Sean
> Sean Gillies
> sgillies at frii dot com
> http://users.frii.com/sgillies
