Problem with Mapscript + PostGIS
Sean Gillies
sgillies at FRII.COM
Thu Jan 27 13:53:04 EST 2005
On Jan 27, 2005, at 12:00 PM, Abe Gillespie wrote:
> --Apple-Mail-24--303801657
> Content-Transfer-Encoding: quoted-printable
> Content-Type: text/plain;
> charset=US-ASCII;
> format=flowed
> I'm compiling everything on Windows. MapServer CGI compiles fine
> with=20=
> "mapserv -v" giving:
> MapServer version 4.4.1 OUTPUT=3DGIF OUTPUT=3DPNG OUTPUT=3DJPEG =
> OUTPUT=3DWBMP=20
> SUPPORTS=3DPROJ SUPPORTS=3DFREETYPE SUPPORTS=3DWMS_SERVER
> INPUT=3DPOSTGIS=20=
> INPUT=3DOGR INPUT=3DGDAL INPUT=3DSHAPEFILE DEBUG=3DMSDEBUG=00
> I also don't have any problem compiling the C# version of Mapscript.
> =20
> But when I try to access a PostGIS layer the logs tell me I don't
> have=20=
> PostGIS support available. Here's the error:
> Thu Jan 27 13:18:39 2005 - msPOSTGISLayerOpen(): Query error.=20
> msPOSTGISLayerOpen called but unimplemented! (mapserver not
> compiled=20
> with postgis support)
> Thu Jan 27 13:18:39 2005 - msDrawMap(): Image handling error. Failed
> to=20=
> draw layer named 'Roads'.
> I know C# Mapscript is brand new ... so help however you can. BTW -
> is=20=
> there a way to do the same as "mapserv -v" in Mapscript? Something=20
> like mapObj::version I'd imagine.
> Thanks.
> -Abe=
There is mapscript::MS_VERSION, but it is only the version string. I
like the idea, you should enter it in Bugzilla as a mapscript
enhancement.
Without the benefit of any other information, I guess that you have
some DLL mixup. Some DLL without libpq is getting in the way.
cheers,
Sean
Sean Gillies
sgillies at frii dot com
http://users.frii.com/sgillies
