mapfile join
Richard Greenwood
richard.greenwood at GMAIL.COM
Thu Jan 27 19:24:33 EST 2005
On Wed, 26 Jan 2005 13:01:21 +0200, John Spotten
<John.Spotten at capetown.gov.za> wrote:
> Hi,
> looking for some sample code showing a join use successfully. get a parsing
> error when using it under class. put it under layer, no parsing error but
> then XP tells me mapserv.exe has found a problem and is closing down.
> using mapserver 4.4.0 on XP and I get error on html page msDBFJoinConnect():
> Unable to access file. (c:\ms4w\apps\mapserver_demos\ct\data\join.dbf). any
> clues. can i use a dbf file.
> I am trying to join to a shape file a seperate independent dbf file on a
> common field that is indexed in the shape file. the field is text type.
> I take it it can be accessed using the [join_<join_name>] template in a
> query template file for a one to many join where [join_<join_name>] gets
> replaced with the join header template and footer files and I assume that
> the template within the query template file is
> [<join_name>_<dbf_field_name>].
> Is it possible to refer to the qlayer as [join_<join_name>]?
> bye
> john
> John Spotten
> Transport Modeller/GIS Developer
> Directorate of Transport, Roads and Stormwater
> City of Cape Town
> Tel : +27 21 4067325
> Fax : +27 21 4186989
> Cell : +27 846678901
> Email : john.spotten at capetown.gov.za
> Web : www.capetown.gov.za
> <<John Spotten.vcf>>
I was hoping somebody else would respond to this with a better
example, but here's an sloppy example that I dug out:
LAYER
NAME "join_query"
GROUP "ownership"
TYPE QUERY
STATUS ON
DATA "/Tc/temp/parcel_region"
HEADER "attribute_header.html"
FOOTER "attribute_footer.html"
TEMPLATE "attribute_display.html"
# FILTERITEM "PID"
# FILTER /./ # regular expression - match anything
JOIN # JOIN no longer lives inside of CLASS or inside a QUERY object
NAME "test"
TABLE "/Tc/temp/assessor2.DBF"
FROM PIDP
TO PIDA
TYPE single # multiple
# TEMPLATE cat.html # required only for one-to-many joins
END # of JOIN Object
END # LAYER "join_region"
Yes, you can use a dbf file. In your TABLE clause, try replacing your
"\" with "/" and/or qouting the string.
HTH
Richard Greenwood
richard.greenwood at gmail.com
www.greenwoodmap.com
