PHP Mapscript getLayerByName
Godwin, Elizabeth
Godwinl at AGR.GC.CA
Fri Jan 28 10:20:09 EST 2005
That's fine for me for now. Thanks! I keep forgetting about using "@".
Cheers,
Liz
> -----Original Message-----
> From: Yewondwossen Assefa [mailto:assefa at dmsolutions.ca]
> Sent: January 28, 2005 10:16 AM
> To: Godwin, Elizabeth
> Cc: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] PHP Mapscript getLayerByName
> Hi There,
> The php waring generated can be supressed using a @ (something like
> @$oLayer = $oMap->getLayerByName("notvalidlayer");) and then you can
> validate the value of $oLayer. Is this accepatable ?
> In my opnion, the default behaviour of generating a php
> waring is ok
> since It can be suppressed for those would do not want the
> warnings. I
> agree It should make it to the docs but I guess most (maybe
> all) of the
> wranings gnerated are not documented so If it is done It must be done
> for all. Another point is that we haven't be very consistent
> or defined
> a clear guide line on what type of error a function is
> suppose to return
> for diffrent scenarios. There is a need to revisit this at
> one point
> and have the warings/erros consistent through all the
> mapscript flavors
> but then again It is a long process to pass through all the functions.
> I have updated bug 1184 with this info.
> Later,
> Godwin, Elizabeth wrote:
> > Hello,
> > I've been trying to use getLayerByName function and it's returning a
> > warning when I use it. I just want to verify if I am doing
> something
> > wrong, before I file a bug, if it's a bug. I've tried this on 4.2,
> > 4.4 and CVS from a week ago, all yield the same warning.
> > From what I understand, the function returns the layer object if it
> > finds the layer, and FALSE if it doesn't. I'm getting
> FALSE *AND* a
> > warning message.
> > _code snippit:_
> > //returns the layer object ok.
> > $oLayer = $oMap->getLayerByName("validlayername");
> > //retuns FALSE and error
> > *Warning*: getLayerByName failed for : notvalidlayer in ...
> > Thanks,
> > Liz Godwin
> Assefa Yewondwossen
> Software Analyst
> Email: assefa at dmsolutions.ca
> http://www.dmsolutions.ca/
> Phone: (613) 565-5056 (ext 14)
> Fax: (613) 565-0925
