Layer drawing
Alex Chimarios
alhim at INTRACOM.GR
Mon Jan 31 09:18:12 EST 2005
I moved a step further with my PDA-mapscript application :
I run the cross-compiled shp2img and it also draws an empty image without
layers.There is a message after the program terminates : "turning off NDELAY
mode "
I would like to ask you which is the library for concatenating images from
different layers and forming the final map image? Is it gd or gdal ?
Thanx, in advance
Alexandros
p.s : tested the source with the same mapfile and data in my Linux i686 and
run correctly.
