Mapserver html output and DOCTYPE...
Kralidis,Tom [Burlington]
Tom.Kralidis at EC.GC.CA
Mon Jan 31 21:35:28 EST 2005
I had a similar issue using MapServer CGI and trying to write xhtml strict, for example. And there's much more than the doctype issues. For example, strict xhtml writes the SELECTED token in a select option as selected="selected". Currently MapServer writes as the former.
Not sure what the best approach is here to solve different more strict HTML flavours and how MapServer outputs form type values.
..Tom
> -----Original Message-----
> From: UMN MapServer Users List
> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of
> Fortin,Nicolas [SteFoy]
> Sent: Monday, 31 January, 2005 16:21
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: [UMN_MAPSERVER-USERS] Mapserver html output and DOCTYPE...
> Hi list,
> Is there a way to remove the mapserv -v output commented at
> the beggining of the output html when using template file
> with mapserver??
> I explain: I use DOCTYPE declaration for my xhtml to be valid
> and for Internet Explorer 6, DOCTYPE declaration MUST be at
> the first line of the xhtml. If it's not, IE pass in quirk
> mode and the layout is not really what expected.
> If not, perhaps future version should put this comment
> elsewhere in the output. We, w3c compliant xhtml coder, will
> be really grateful :)
> Thanks,
> Nicolas Fortin
> Mathématicien, Programmeur, Analyste de données
> SMC-Québec Hydrologie, Environnement Canada
> 1141, Rte de l'Église, Sainte-Foy(QC) G1V 4H5
> (418)648-2516
