Res: Re: [UMN_MAPSERVER-USERS] Fw: Postgis Connection
Benjamin Thelen
bt at CCGIS.DE
Fri Jul 1 05:32:10 EDT 2005
Ezequias Rodrigues da Rocha wrote:
> I didn't find the tcpip_socket parameter and put it in sume point on my
> postgresql.conf.
> But now I can't start my postgresql 8.0 (# ./postmaster -D
> /usr/local/pgsql/data)
> Please see what is wrong
> The error reported was:
> [postgres at mangueira bin]$ FATAL: unrecognized configuration parameter
> "tcpip_socket"
> My pg_hba.conf is:
> [postgres at mangueira data]$ more pg_hba.conf
> # TYPE DATABASE USER CIDR-ADDRESS METHOD
> # "local" is for Unix domain socket connections only
> local all all trust
> # IPv4 local connections:
> host all all 10.0.0.0 255.0.0.0 password
> host all all 192.168.0.0 255.0.0.0 password
> host all all 127.0.0.1/32 trust
> host all all 200.249.133.135 255.255.255.255
> password
> # IPv6 local connections:
> host all all ::1/128 trust
> I believe there is no problem because I am on the network 10 and the
> server on the 192
> Some more advices ?
> Best regards
> Ezequias
> /-------Mensagem original-------/
> /*De:*/ Benjamin Thelen <mailto:bt at CCGIS.DE>
> /*Data:*/ 06/30/05 12:43:52
> /*Para:*/ MAPSERVER-USERS at LISTS.UMN.EDU
> <mailto:MAPSERVER-USERS at LISTS.UMN.EDU>
> /*Assunto:*/ Re: [UMN_MAPSERVER-USERS] Fw: Postgis Connection
> > I am trying to load a mapserver service with a postgis connection but
> > the MS reported this message below:
> > msDrawMap(): Image handling error. Failed to draw layer named 'bairros'.
> > msPOSTGISLayerOpen(): Query error. couldnt make connection to DB with
> > connect string 'user=postgres password=post dbname=dbpotgis
> > host=lab1.recife port=5432'.
> > Error reported was 'could not create socket: Permission denied '.
> > This error occured when trying to make a connection to the specified
> > postgresql server.
> > Most commonly this is caused by
> > (1) incorrect connection string
> > (2) you didnt specify a 'user=...' in your connection string
> > (3) the postmaster (postgresql server) isnt running
> > (4) you are not allowing TCP/IP connection to the postmaster
> > (5) your postmaster is not running on the correct port - if its not on
> > 5432 you must specify a 'port=...'
> > (6) the security on your system does not allow the webserver (usually
> > user 'nobody') to make socket connections to the postmaster
> > (7) you forgot to specify a 'host=...' if the postmaster is on a
> > different machine
> > (8) you made a typo
> > Does anyone can tell me what to do ?
> > Atenciosamente (Sincerely)
> > *Ezequias Rodrigues da Rocha*
> > *** *www.recife.pe.gov.br
> <http://www.recife.pe.gov.br>*
> > <http://www.recife.pe.gov.br/>
> > A pior das democracias ainda é melhor do que a melhor das ditaduras
> > The worst of democracies is still better than the better of dictatorships
> > MSN Messenger: ezequias at hotmail.com <mailto:ezequias at hotmail.com>
> > Add FUN to your email - CLICK HERE!
> > <http://www.incredimail.com/index.asp?id=54760>
> Ezequias,
> Well, I think one cannot make more suggestions you already got from the
> error messages!
> I assume your postgres is running and your connection string is correct,
> but you should send it to the list, too.
> A common error is, that the postgresql-server does not accept tcp/ip
> connections. Check your postgresql.conf: "tcpip_socket = true" must be
> there.
> Second, check your pg_hba.conf: There has to be an entry that allows
> your "mapserver-host" to connect to the server, such as
> for remote access of the network 192.168.100.0:
> host all all 192.168.100.0 255.255.255.0 trust
> or for local access, if mapserver and pgsql are on the same host:
> host all all 127.0.0.1 255.255.255.255 trust
> Hope, that helps!
> Ben
Ezequias,
As you're using postgresql 8, you must remove the tcpip_socket
parameter, because it's a paramater used in earlier postgresql versions.
Look again into your posgresql.conf. You'll need to have the following
at the beginning of the file:
listen_addresses = '*' # what IP interface(s) to listen on;
# defaults to localhost, '*' = any
Restart pgsql.
Ben
