Res: Re: [UMN_MAPSERVER-USERS] Res: Re: [UMN_MAPSERVER-USERS]
Res: Re: Res: Re: [UMN_MAPSERVER-USERS] Fw: Postgis Connection
Benjamin Thelen
bt at CCGIS.DE
Fri Jul 1 08:45:23 EDT 2005
Ezequias Rodrigues da Rocha wrote:
> Some other thing.
> The server doesn't have the "postgres" user (linux system).
> The user "postgres" is from the postgresql.
> I hope you understands what I means.
> Best regards
> Ezequias
> /-------Mensagem original-------/
> /*De:*/ Benjamin Thelen <mailto:bt at CCGIS.DE>
> /*Data:*/ 07/01/05 09:02:12
> /*Para:*/ MAPSERVER-USERS at LISTS.UMN.EDU
> <mailto:MAPSERVER-USERS at LISTS.UMN.EDU>
> /*Assunto:*/ Re: [UMN_MAPSERVER-USERS] Res: Re: [UMN_MAPSERVER-USERS]
> > All looks to be correct. I am becoming to be worried.
> > ps: Your e-mails are comming twice. Some times three times. Check it out.
> > Thank you for your attention
> > Sincerely
> > ezequias
> > /*Data:*/ 07/01/05 08:16:01
> > /*Assunto:*/ Re: [UMN_MAPSERVER-USERS] Res: Re: Res: Re:
> > > I do heve this line. See below:
> > > # CONNECTIONS AND AUTHENTICATION
> > > # - Connection Settings -
> > > listen_addresses = '*' # what IP interface(s) to listen on;
> > > # defaults to localhost, '*' = any
> > > port = 5432
> > > max_connections = 100
> > > Still waitting
> > > Ezequias
> > > /*De:*/ Benjamin Thelen <mailto:bt at ccgis.de>
> > > /*Data:*/ 07/01/05 05:55:31
> > > /*Para:*/ Ezequias Rodrigues da Rocha
> <mailto:ezequias at recife.pe.gov.br>
> > > /*Cc:*/ Benjamin Thelen <mailto:bt at ccgis.de>
> > > /*Assunto:*/ Re: Res: Re: [UMN_MAPSERVER-USERS] Fw: Postgis Connection
> > > > I didn't find the tcpip_socket parameter and put it in sume point
> > on my
> > > > postgresql.conf.
> > > > But now I can't start my postgresql 8.0 (# ./postmaster -D
> > > > /usr/local/pgsql/data)
> > > > Please see what is wrong
> > > > The error reported was:
> > > > [postgres at mangueira bin]$ FATAL: unrecognized configuration
> parameter
> > > > "tcpip_socket"
> > > > My pg_hba.conf is:
> > > > [postgres at mangueira data]$ more pg_hba.conf
> > > > # TYPE DATABASE USER CIDR-ADDRESS METHOD
> > > > # "local" is for Unix domain socket connections only
> > > > local all all trust
> > > > # IPv4 local connections:
> > > > host all all 10.0.0.0 255.0.0.0 password
> > > > host all all 192.168.0.0 255.0.0.0 password
> > > > host all all 127.0.0.1/32 trust
> > > > host all all 200.249.133.135 255.255.255.255
> > > > password
> > > > # IPv6 local connections:
> > > > host all all ::1/128 trust
> > > > I believe there is no problem because I am on the network 10
> and the
> > > > server on the 192
> > > > Some more advices ?
> > Ezequias,
> > You can ping the pgsql-server from your mapserver-server?
> > # ping lab1.recife
> > The pgsql-server listens on port 5432? Check with:
> > # netstat -tan -ptcp.
> > You corrected the typo "dbname=dbpotgis"?
> > You are sure about the password for the dbuser? Can you log into the
> > database from the command line and access the tables?
> > # psql -Upostgres -ddbpostgis
> > If you are not sure about the password, change "password" to "trust" in
> > pg_hba.conf. Also, I would recommend to change "password" to "md5" for
> > encrypted passwords.
> > Well, at the moment, I have no more ideas, sorry!
> > Ben
> > > > Best regards
> > > > Ezequias
> > > > /*Data:*/ 06/30/05 12:43:52
> > > > /*Assunto:*/ Re: [UMN_MAPSERVER-USERS] Fw: Postgis Connection
> > > > > I am trying to load a mapserver service with a postgis
> > connection but
> > > > > the MS reported this message below:
> > > > > msDrawMap(): Image handling error. Failed to draw layer named
> > > 'bairros'.
> > > > > msPOSTGISLayerOpen(): Query error. couldnt make connection to
> > DB with
> > > > > connect string 'user=postgres password=post dbname=dbpotgis
> > > > > host=lab1.recife port=5432'.
> > > > > Error reported was 'could not create socket: Permission
> denied '.
> > > > > This error occured when trying to make a connection to the
> > specified
> > > > > postgresql server.
> > > > > Most commonly this is caused by
> > > > > (1) incorrect connection string
> > > > > (2) you didnt specify a 'user=...' in your connection string
> > > > > (3) the postmaster (postgresql server) isnt running
> > > > > (4) you are not allowing TCP/IP connection to the postmaster
> > > > > (5) your postmaster is not running on the correct port - if its
> > not on
> > > > > 5432 you must specify a 'port=...'
> > > > > (6) the security on your system does not allow the webserver
> > (usually
> > > > > user 'nobody') to make socket connections to the postmaster
> > > > > (7) you forgot to specify a 'host=...' if the postmaster is on a
> > > > > different machine
> > > > > (8) you made a typo
> > > > > Does anyone can tell me what to do ?
> > > > > Atenciosamente (Sincerely)
> > > > > *Ezequias Rodrigues da Rocha*
> > > > > *** *www.recife.pe.gov.br
> <http://www.recife.pe.gov.br>
> > > > <http://www.recife.pe.gov.br>*
> > > > > <http://www.recife.pe.gov.br/>
> > > > > A pior das democracias ainda é melhor do que a melhor das
> ditaduras
> > > > > The worst of democracies is still better than the better of
> > > dictatorships
> > > > > MSN Messenger: ezequias at hotmail.com
> <mailto:ezequias at hotmail.com> <mailto:ezequias at hotmail.com>
> > > > > Add FUN to your email - CLICK HERE!
> > > > > <http://www.incredimail.com/index.asp?id=54760>
> > > > Ezequias,
> > > > Well, I think one cannot make more suggestions you already got
> > from the
> > > > error messages!
> > > > I assume your postgres is running and your connection string is
> > correct,
> > > > but you should send it to the list, too.
> > > > A common error is, that the postgresql-server does not accept
> tcp/ip
> > > > connections. Check your postgresql.conf: "tcpip_socket = true"
> must be
> > > > there.
> > > > Second, check your pg_hba.conf: There has to be an entry that
> allows
> > > > your "mapserver-host" to connect to the server, such as
> > > > for remote access of the network 192.168.100.0:
> > > > host all all 192.168.100.0 255.255.255.0
> > > trust
> > > > or for local access, if mapserver and pgsql are on the same host:
> > 255.255.255.255 trust
> > > > Hope, that helps!
> > > > Ben
> > > Ezequias,
> > > As you're using postgresql 8, you must remove the tcpip_socket
> > > parameter, because it's a paramater used in earlier postgresql
> versions.
> > > Look again into your posgresql.conf. You'll need to have the following
> > > at the beginning of the file:
> > > Restart pgsql.
> > > Ben
> Ezequias,
> Please always reply to the list!
> Of course you receive the mails twice. One Mail goes to the list and the
> other to you directly. Some list-members only reply to the list, but
> most reply to both.
> Another point, please do not top post!
> I'm afraid, that I have no more ideas! Your problem needs hard debugging
> Install pgadmin-III and/or phppgadmin and try to connect to your
> pgsql-server from your mapserver-server, also you could try to connect
> from your remote machine from command-line with "psql -Upostgres
> -hlab1.recife -ddbpostgis".
> As your machines are on different network segments, it is quite likely,
> that port 5432 is blocked by a firewall - you have to ask your IT to
> unlock this port.
> Ben
Ezequias,
1. Reply to the list, please.
2. Don't top post, please.
3. Do not change the subject line, please.
You need to have two accounts, one for the system, to start the
postmaster and of course on as the database super user, which we are
talking about.
Did you explicitely change the password for the database super user
"postgres"?
Ben
