error when connecting to demo
Bart van den Eijnden bartvde at XS4ALL.NL
Sun Jul 3 07:42:53 PDT 2005
Hi guys,
I ran into this as well.
Steve Lime pointed out that none was a new keyword introduced with 4.6 for
cartolines.
I first thought also all string values should be quoted starting 4.6, but
this is not the case as yet, the reason is none being a new keyword.
Best regards,
Bart
On Thu, 30 Jun 2005 19:49:03 +0200, Emil Zegers <taatuut at PLANET.NL> wrote:
> I believe with the new 4.6 version of MapServer all string values
> should be enclosed with double quotes.
> You'll probably find a lot of demos with 'old' .map files that need to
> be updated for this.
> Regards,
> Emil
> ----- Oorspronkelijk bericht -----
> Van: Philip Dillon-Thiselton <dibblethewrecker at JIWE.ORG>
> Datum: donderdag, juni 30, 2005 6:50 pm
> Onderwerp: Re: [UMN_MAPSERVER-USERS] error when connecting to demo
>> OK - i figured out that
>> WMS_ACCESSCONSTRAINTS none
>> should be
>> WMS_ACCESSCONSTRAINTS "none"
>> That should probably be changed in the .zip archive.  After a bit of
>> jiggling with the index.html file it is all working.
>> Thanks for the .map file pointer
>> Phil
>> Philip Dillon-Thiselton wrote:
>> > Ok - here is the output below from the itasca.map file - this was
>> > unchanged from the version in the .zip file until i just changed
> the
>> > WMS_ONLINERESOURCE to see if that fixed it - it did not.
>> > I am using the latest Mapserver and latest demo files from
>> > workshop.zip - they are built from src by me in linux.
>> >    METADATA
>> >      WMS_TITLE "UMN MapServer Itasca Demo"
>> >      WMS_ABSTRACT "This is a UMN MapServer application for Itasca
>> > County located in north central Minnesota."
>> > 73      WMS_ACCESSCONSTRAINTS none
>> >      # change this value to match your setup
>> >      WMS_ONLINERESOURCE "http://heaton/mapserver_demo/index.html"
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
More information about the MapServer-users mailing list
