transparency not working in dynamic layer
Lowell Filak
lfilak at MEDINACO.ORG
Tue Jul 5 08:26:28 EDT 2005
The following message was sent by Mark Phillips <mbp at GEOMTECH.COM> on
Mon, 4 Jul 2005 19:28:38 -0500.
> Hi,
> I'm using Perl mapscript to manually draw a rectangle on a map. I'd
> like the rectangle to be transparent, so I'm drawing it in a layer
> that is already defined in the mapfile as follows:
> LAYER
> NAME RECT
> STATUS ON
> TYPE POLYGON
> TRANSPARENCY 50
> CLASS
> COLOR 210 210 150
> OUTLINECOLOR 0 0 0
> END
> END
> The rectangle always comes out opaque, though. Here's the relevant part
> of my perl script:
> $map = new mapscript::mapObj( ... );
> $img = $map->draw();
> $layerobj = $map->getLayerByName('RECT');
> $layerobj->{status} = 1;
> $rectobj = new mapscript::rectObj();
> $rectobj->{minx} = -82.331429;
> $rectobj->{maxx} = -82.323929;
> $rectobj->{miny} = 35.508876;
> $rectobj->{maxy} = 35.516376;
> $rectobj->draw($map, $layerobj, $img, undef, "");
> $img->save($filename);
> Does anyone know what I'm doing wrong? I've seen references to
similar problems
> with transparency in dynamic layers in the list archives, but I
haven't seen
> a resolution.
Mark,
I'm not sure if you can perform a map->draw before you draw the
transparent layer and expect it to be transparent.
Can you use a shapeobj & addfeature to the layer before performing the draw?
Lowell
