Raster Layer, Extent, etc.
Ian Harding
iharding at TPCHD.ORG
Tue Jul 5 17:38:03 EDT 2005
Thanks! Of course projections are important, I just thought I could
"ignore" them for now, I guess not!
Is there a good tutorial on the required incantations for the PROJECTION
blocks? I have found a few links but nothing that really enlightened me
much.
- Ian
>>> "Fawcett, David" <David.Fawcett at state.mn.us> 07/05/05 2:11 PM >>>
Projections may make our data look 'funny', but it also lets us put
features from the 3D globe on 2D paper or screens.... ; ]
By enabling projections in MapServer, it allows us to gather data in
several different projections and use them all in the same output map.
I would go back to your data sources and find out what projection the
data sets are in. There are a lot of possible projections, so it is
difficult to guess the projection by trial and error. Better to just
contact the data provider and get the original info. If someone is
familiar with The large numbers in the extents of your counties data set
could possibly be feet or meters.
ALSO, I just noticed your MAP PROJECTION block. You are requesting both
"latlong" and "init=epsg:32149" Try choosing one or the other, you
can't have both at the same time.
David Fawcett
Minnesota Office of Environmental Assistance
david.fawcett at moea.state.mn.us
651.215.0200
-----Original Message-----
Sent: Tuesday, July 05, 2005 3:57 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU; David.Fawcett at state.mn.us
Subject: RE: [UMN_MAPSERVER-USERS] Raster Layer, Extent, etc.
Thanks for the reply! I fooled around a bit with those blocks (added
one to 'counties' too) with no luck. As I understand projections, they
might make my data look funny, but it should at least show up, right? I
have zoomed and panned like crazy and can't find it.
Also, in the "proj=????" bit, what other options are there besides
latlong? This coordinate system seems to have some awfully big numbers,
that don't look like latlong to me.
I am missing something very simple here, no doubt. Doh!
Thanks,
Ian
>>> "Fawcett, David" <David.Fawcett at state.mn.us> 07/05/05 1:43 PM >>>
Ian,
I am guessing that the projection is causing your issues.
The projection block in the MAP object (at the top of the map file)
applies to the whole map file. You set this to the projection that you
want to output your data in. The EXTENT and UNITS should be in the
units of this projection.
In each LAYER, you need to define the projection that the input data for
that layer is in. So, you have a PROJECTION .... END block in each
layer.
At a minimum, you need to add a PROJECTION block to your 'counties'
layer. From your description, your raster may be unprojected (lat lon).
David.
David Fawcett
651.215.0200
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]On
Behalf Of Ian Harding
Sent: Tuesday, July 05, 2005 3:21 PM
Subject: [UMN_MAPSERVER-USERS] Raster Layer, Extent, etc.
I have no idea what I am doing.
I can get mapserver to work as advertised with vector data (geographic
coordinate system) and with raster data (some other crazy coordinate
system) but can't get the twain to meet.
When I change the extent (as seen in the commented section) one or the
other layers will display, but not both. I have controls that
successfully turn the layers off and on in isolation, so I know it's not
the DEFAULT versus ON issue.
The system seems to be very forgiving of bad stuff (or absense of any
stuff) in the "projection" section, and the "units" just screws up the
scalebar, but the "extent" seems to be killing me.
There is only one "extent" section, which applies to the whole mapfile,
right? From what I have read, the various layers can use different
coordinate systems and be 'translated' to the overall mapfile extent and
coordinate system. This is not working for me.
What could be causing my pain here?
Thank you in advance....
- Ian
MAP
IMAGETYPE PNG24
EXTENT -122.5 46.5 -121.8 47.8
UNITS DD
# Uncommenting these (and commenting the above) makes the raster image
appear.
# EXTENT 1060000.000000 460000.000000 1460000.000000 660000.000000
# UNITS FEET
SIZE 400 300
SHAPEPATH "pierceco"
IMAGECOLOR 255 255 255
PROJECTION
"proj=latlong"
"datum=NAD83"
"init=epsg:32149"
END
SYMBOLSET "symbols/symbols35.sym"
FONTSET "fonts/fonts.list"
WEB
TEMPLATE 'pierce.html'
IMAGEPATH '/data/tmp/'
IMAGEURL '/tmp/'
END
# Start of scalebar
SCALEBAR
LABEL
COLOR 0 0 0
SIZE TINY
END
STYLE 1
SIZE 100 2
COLOR 0 0 0
UNITS MILES
INTERVALS 2
TRANSPARENT FALSE
STATUS ON
END
# Start of LAYER DEFINITIONS
LAYER
CONNECTIONTYPE postgis
NAME "counties"
# Connect to a remote spatial database
CONNECTION "user=user dbname=dbname host=localhost"
DATA "the_geom from gis.wa_counties"
STATUS ON
TYPE POLYGON
FILTER "true"
LABELITEM "name"
CLASS
COLOR 232 232 232
OUTLINECOLOR 32 32 32
LABEL
COLOR 0 0 0
OUTLINECOLOR 255 255 255
TYPE TRUETYPE
FONT arial
SIZE 10
ANTIALIAS TRUE
END
END
END
LAYER
NAME "relief"
STATUS ON
TILEINDEX "topo.shp"
TILEITEM "location"
TYPE RASTER
# PROJECTION
# I was told this data was in "State Plane Feet NAD 83 WA South
4602"
# Have tried all kinds of incantations in this section to no
effect.
# END
END
# End of LAYER DEFINITIONS -------------------------------
END # end of map file/object
