using Mapserver for on-the-fly raster data?
Sean Gillies
sgillies at FRII.COM
Wed Jul 6 12:07:44 EDT 2005
On Jul 6, 2005, at 9:32 AM, Jeff de La Beaujardiere wrote:
> I have a set of huge raw binary datafiles containing output from
> someone's numerical simulation (6GB/file, 4files/day). Each file
> contains values for a variety of atmospheric quantities, each at 20
> timesteps, and some at multiple elevations. I would like to offer
> access to at least some of the quantities via WMS protocol using
> Mapserver.
> The brute force way works: I can pre-generate PNG or GeoTIFF images of
> selected quantities, and then generate a mapfile that includes all the
> images. The obvious disadvantage is that I will have many files laying
> around whether they ever get used or not.
> I would like a more elegant approach, wherein Mapserver's WMS service
> metadata can advertise what quantities are available, but the data are
> extracted from the 6GB model file only upon request. Is it possible to
> do something like this? I see a few mentions of database connections
> in the Mapserver documentation but must admit that I am somewhat
> mystified.
> Thanks for any help,
> Jeff DLB
Jeff,
You could take advantage of MapServer's cascading WMS, and of
MapServer's easy-going WMS client nature. Create a custom service (as a
CGI or servlet or whatever) that responds to WMS GetMap requests and
generates a response on-the-fly from your model output. Next, stand up
a MapServer WMS between this half-baked service and your end users. All
the capabilities metadata would be defined in this mediating service.
As a WMS client, MapServer doesn't care whether the service it requests
from implements all the WMS spec, it only needs GetMap.
cheers,
Sean
Sean Gillies
sgillies at frii dot com
http://zcologia.com
