Connect to ESRI Personal Geodatabase
Ken Lord
kenlord at GMAIL.COM
Wed Jul 6 12:48:24 EDT 2005
Thanks for the responses,
Frank, are you saying that right now mapserver can read spatial data from a
personal geodatabase using an ODBC connection (and if so, are there any
exampes available)? Or would some amount of work needed to add the
functionality?
Thanks,
Ken Lord
Vancouver BC
On 7/6/05, Frank Warmerdam <fwarmerdam at gmail.com> wrote:
> On 7/6/05, Paul Ramsey <pramsey at refractions.net> wrote:
> > Frank has much of the infrastructure needed already in OGR (ODBC
> > driver, etc) and I have been told that the geodatabase internal
> > spatial format is very simple (shapefile-in-a-table). All you need to
> > do is scrape together the funding. I bet if you asked, he'd write up
> > a quote for free.
> Folks,
> My understanding is that the personal geodatabase table organization
> is significantly different than the ArcSDE RDBMS organization. Also,
> keep in mind that the MapServer SDE support uses the SDE libraries
> to do all the access. For personal geodatabases my preferred
> approach is to use direct ODBC access to the .mdb file without any
> direct dependence on ESRI software so that folks can work with
> personal geodatabases even without SDE or other ESRI libraries
> being installed.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050706/a377056d/attachment.html
