using Mapserver for on-the-fly raster data?
Jeff de La Beaujardiere
jeff2005 at SVS.GSFC.NASA.GOV
Wed Jul 6 15:49:32 EDT 2005
Frank Warmerdam wrote:
> Note that there is a builtin limit on the number of layers. You may
> need to recompile with a higher limit if you will end up serving a
> very large number of layers.
Already recompiled with layer limit 10000!
> As of 4.6 (actually it might have been in 4.4 too), MapServer supports
> the ability to apply classification to non-8bit raster data. This is discussed
> in the raster howto at:
> http://ms.gis.umn.edu/docs/howto/raster_data
Thank you--I had ignored and forgotten that section of the Raster Howto,
but I see that it may be just the ticket here. My other dataset is
satellite imagery that I serve as-is [By the way, the performance of the
GeoTIFFs with overviews built using GDAL is *phenomenal* compared to
serving the PNGs that I get from my source.]
> Well, then you need to implement the full WMS support. I was just
> suggesting that your preprocessor would find the LAYERS info,
> and use it to pull the required dataset out of the "big file" before
> processing the request. This leaves MapServer doing all the
> subsetting, classification etc.
Given what you just told me about raster classification, this is indeed
a possibility.
> However, if you were to start from the python WMS that Allan wrote
> for his WMS cookbook you might well be able to implement a small
> custom WMS service calling out to IDL to do some of the work.
Actually, I already have my own custom WMS using Perl + IDL that we used
for the GLOBE Program (www.globe.gov), but it would require so dusting
off and retooling. I definitely would prefer to use Mapserver if possible.
Many thanks,
Jeff DLB
