No labels with tileindex layer
Hunter, David - St. Louis Park, MN
David.Hunter at FNF.COM
Wed Jul 6 17:53:32 EDT 2005
My apologies to all, I was not patient enough for the results to show up
in the browser. It was working after all, but was incredibly slow. I
set FORCE to "true" in the labels layer, and it improved quite a bit.
_____
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Hunter, David - St. Louis Park, MN
Sent: Wednesday, July 06, 2005 3:27 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] No labels with tileindex layer
I am putting together a demo app using DHTML, MapServer 4.4.1 CGI,
Tomcat 5 and Win2000. I am using MapInfo .tab files for vector data,
accessing via OGR.
I would like my app to enable users to turn layers and labels on/off. I
have the layers working, and started on the labels when I ran into a
problem. I made two separate layers per layer type, one for the
features and one for the labels, so that they could be turned on/off
independently. This worked as expected for a point layer. However, I
have a few layers in tileindexes that I created using the ogrtindex
utility. These features draw fine, but trying to label them causes
MapServer to go into some kind of unresponsive state. Here is a snippet
from my .map file to show how I tried to do this:
# major roads
LAYER
NAME "Roads_Labels"
CONNECTIONTYPE OGR
TILEINDEX "roadbase/roads.tab"
STATUS OFF
TYPE ANNOTATION
PROJECTION
"init=epsg:4267"
END
LABELITEM "hwyname"
CLASS
LABEL
TYPE TRUETYPE
FONT arial
SIZE 6
COLOR 255 0 0
OUTLINECOLOR 255 255 255
ANTIALIAS TRUE
ANGLE auto
FORCE true
POSITION auto
OFFSET 0 0
END
END
END
LAYER
NAME "Roads"
CONNECTIONTYPE OGR
STATUS OFF
TYPE LINE
PROJECTION
"init=epsg:4267"
END
CLASS
COLOR 255 0 0
SIZE 2
END
END
Is this not possible to do, or is there a workaround or alternative
method? TIA!
David S. Hunter
Sr. Software Engineer
Fidelity National Geographic Solutions
division of Fidelity National Financial
5353 Gamble Drive, Suite 201
St. Louis Park, MN 55416
* Email: david.hunter at fnf.com
' Phone: 952.542.1440 ext. 256
* Fax: 952.542.3859
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050706/3ac77ec6/attachment.html
