Projection LAMBERT III (South of France) parameters
Frank Warmerdam
fwarmerdam at GMAIL.COM
Thu Jul 7 09:46:13 EDT 2005
On 7/7/05, Selim Hernandez <pimpoumvlan at hotmail.com> wrote:
> Hello,
> I can't find the right PROJECTION object's parameters in my .map file for
> coords in LAMBERT III (used for the South of France).
> Though, when I translate these coords into the WGS 84 system (epsg:4326),
> it works fine.
> Maybe the coords in the epsg file are wrong.
> I used the following parameters and none of them worked :
> "proj=lcc"
> "lat_1=44.10000000000001"
> "lat_0=44.10000000000001"
> "lon_0=2.33722917"
> "k_0=0.999877499"
> "x_0=600000"
> "y_0=200000"
> "a=6378249.2"
> "b=635651"
> "pm=paris"
> "units=m"
Selim,
There is an issue with the automated conversion from EPSG into
PROJ.4 syntax for coordinate system using gradians for angular
values. I think the angular->degree translation is happening twice.
Could you try using lat_0=49 and lat_1=49?
Alternatively, it might be that the prime meridian is being improperly
applied. If so, try setting lon_0=0.
I do appologise for this botching of some complex coordinate systems.
I have had some open bug reports on it for some time, but haven't gotten
back to deal with it properly.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
