GRIDS and Graticule
Brent Fraser bfraser at GEOANALYTIC.COM
Thu Jul 7 15:50:50 PDT 2005
François,
  The entry of "MAXINTERVAL 5" likely forces the software to have no more
than 5 degrees between the graticule lines (as shown on your graphic).  What
happens if you remove it?
Brent
----- Original Message -----
To: <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Thursday, July 07, 2005 3:49 PM
Subject: Re: [UMN_MAPSERVER-USERS] GRIDS and Graticule
> Le 12963ième jour après Epoch,
> François TOURDE écrivait:
> > Hi John,
> > Le 12962ième jour après Epoch,
> > John Novak écrivait:
> >> Please attach the .map file you're using
> > I'll do that once I've reduced it. It's 230Ko of data (features
> > layers), and a bad idea on the list.
> > At the same time, I'll put a test url so you can see the result.
> Ok, it's ready now (I'm sorry for the lag...)
> Just for those reading the thread now:
> It seems that the {MIN|MAX}{ARCS|INTERVALS|SUBDIVIDE} parameters
> doesn't works correctly on my .map file.
> Here's the mapfile:
> http://www.tourde.org/tmp/generali.map
> and the result:
> http://www.tourde.org/tmp/maptest.png
> Thanks in advance for any idea.
More information about the MapServer-users mailing list
