GRIDS and Graticule
François TOURDE
fr-ms at TOURDE.ORG
Fri Jul 8 08:54:46 EDT 2005
Le 12972ième jour après Epoch,
Brent Fraser écrivait:
> François,
> The entry of "MAXINTERVAL 5" likely forces the software to have no more
> than 5 degrees between the graticule lines (as shown on your graphic). What
> happens if you remove it?
It works great...
So you can't use MIN/MAX INTERVAL when you specify MIN/MAX ARCS
The road to Hades is easy to travel.
-- Bion
