PHP-MapScript Memory Exhaustion Error
John Gorkos
johng at AMDSWIRELESS.COM
Fri Jul 8 14:50:42 EDT 2005
Gurus-
I am writing a PHP-MapScript script which pulls a list of points from a DB,
and plots them on the map using multiple styles per point. The styles are
dynamically altered in the script to basically draw a small bar graph with 7
bars at each map point, to reflect various health parameters of some remote
equipment.
I have mad this work in perl. Under PHP, I am allowed to add two styles per
point, but when I add the third, I get this:
Fatal error: Allowed memory size of 8388608 bytes exhausted (tried to allocate
75 bytes) in /var/www/html/foo.phtml
The code snippet which produces this is as follows:
$image=$map->draw();
$meterLayer = $map->getLayerByName("Endpoints");
$meterClass0 = $meterLayer->getClass(0);
$rs= mssql_query ($sql, $con);
$red = array(255,255,255,225,0,150,0);
$green = array(255,0,255,0,200,100,0);
$blue = array(255,0,0,150,150,50,255);
while ( $row = mssql_fetch_row($rs)) {
for ( $i=0; $i<3; $i++ ) {
$meterStyle[$i] = $meterClass0->getStyle($i);
$meterStyle[$i]->outlinecolor->setRGB($red[$i],$green[$i],$blue[$i]);
$meterStyle[$i]->color->setRGB($red[$i],$green[$i],$blue[$i]);
$meterStyle[$i]->set('offsetx',$i*3);
$meterStyle[$i]->set('offsety',0);
$point = ms_newPointObj();
$point->setXY((-1)*$row[1],$row[0]);
$point->draw($map,$meterLayer,$image,0,$row[2]);
$image_url=$image->saveWebImage();
If the "3" in the for loop above is set to 2 or 1, it works fine, but I need
it to be an 8, which obviously fails. More code available on request.
I am using Mapserver 2.6, PHP 5.0.4. The machine is 64-bit Mandrake Linux
installation on dual Xeons with 2GB of physical ram, yadda yadda. It's a
healthy machine, and has run this same type of code under 2.6beta3 with Perl
Mapscript. However, I formatted the box to switch from SuSE to Mandrake, and
forgot to copy the perl script over before I formatted the / partition
(insert lots of comments about backups, etc),so I'm rewriting in PHP since I
was shamed into learning in on the #mapserver irc channel.
Anyone have any thoughts on where I'm wrong, or is this a bug?
John Gorkos
AMDS Wireless, LLC
