GetCapabilites Request
Bart van den Eijnden
BEN at SYNCERA-ITSOLUTIONS.NL
Mon Jul 11 07:06:34 EDT 2005
Hi Leopold,
the mime type of a GetCapabilities request is application/vnd.ogc.wms_xml for WMS 1.1.X, so that the file is downloaded by IE is correct since it does not know this mime type by default.
Are you trying to access your localhost WMS server by wmsviewer.com???? I assume the WMS Viewer needs a public WMS service (since it uses ASP as a technlogy), it can't read from your localhost ofcourse! This could only work if the handling by wmsviewer.com would be done completely in javascript in the browser which I don't think it does.
Best regards,
Bart
Syncera IT Solutions
Postbus 270
2600 AG DELFT
tel.nr.: 015-7512436
email: BEN at Syncera-ITSolutions.nl
>>> "Leopold Schefcik (MULTIMEDIAPLAN.AT)" <leopold.schefcik at MULTIMEDIAPLAN.AT> 07/11/05 12:21pm >>>
hi list,
I ve installed a ms4w (incl. umn server and Maplab)
The GetMap Request works fine:
http://localhost/cgi-bin/mapserv.exe?MAP=/ms4w/apps\maplab-2.2\tutorial/cent
rope2.map&SERVICE=wms&VERSION=1.1.1&LAYERS=bathymetry,land_fn&REQUEST=GetMap
At the GetCapabilities Request I get a file (I think xml) as attachement.
(see attachement)
http://localhost/cgi-bin/mapserv.exe?MAP=/ms4w/apps/gmap/htdocs/gmap75_wms.m
ap&SERVICE=wms&VERSION=1.1.1&REQUEST=GetCapabilities
but in viewers (e.g. http://www.wmsviewer.com it won t work.
Maby someone has an idea what s wrong!?
Leopold
