Apache on Port 81
Jacob Delfos
jacob.delfos at MAUNSELL.COM
Tue Jul 12 01:33:43 PDT 2005
Hi Leopold,
Should work fine, as long as you make sure all absolute links point to port 80 (http://localhost:80/.....), so best to use relative links whereever possible, so you don't have to hardcode the port. But be aware that many users may not have access to port 81 (because often company firewalls are set to block all non-standard ports).
regards,
Jacob
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Leopold Schefcik (MULTIMEDIAPLAN.AT)
Sent: 12 July 2005 16:30
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] Apache on Port 81
hi list!
My ms4w is running on my local computer.
Now I want to install it on the windows server
there on port 80 is an IIS installed
I copyed the ms4w directory with e.g. C:/ms4w/apache/... and
C:/ms4w/apache-install.bat) on the server and startet the
apache-install.bat.
But with http://localhost I don´t get the ms4w starting page, but the iis
start page.
So I tried to switch in Apache/conf/ in the files httpd.conf and
httpd.default.conf all 80 to 81. But local nothing changed.
How can I get my ms4w starting page running?
greatings, Leopold
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050712/f95da4b8/attachment.htm>
More information about the MapServer-users
