Splitting/tiling a raster
Bart van den Eijnden
BEN at SYNCERA-ITSOLUTIONS.NL
Tue Jul 12 06:04:44 EDT 2005
You can build overviews with gdaladdo:
http://www.gdal.org/gdal_utilities.html#gdaladdo
Eg:
gdaladdo -r average abc.tif 2 4 8 16
Try that first I would say.
Best regards,
Bart
Syncera IT Solutions
Postbus 270
2600 AG DELFT
tel.nr.: 015-7512436
email: BEN at Syncera-ITSolutions.nl
>>> Stefan Schwarzer <stefan.schwarzer at GRID.UNEP.CH> 07/12/05 12:02pm >>>
> Which format is your raster currently in?
TIF or JPEG
> If it is performance, building overviews could also help for
> certain situations.
So, how can I build overviews then?
> At which scales do you display your raster? Also at full extent?
From full extent (at the beginning - a couple of hundreds km wide)
to then, when zooming, a couple of km wide.
> Best regards,
> Bart
> Postbus 270
> 2600 AG DELFT
>>>> 11:55am >>>
> Thanks Bart for the quick response,
> aehh, yes, performance. But perhaps there is no need to split it up?
> Is it that what you mean? Gush, somehow I don't really get it how
> this tiling works, stupid me....
> Stef
>> Hi Stefan,
>> since gdal_translate has the option to select a subwindow (srcwin)
>> from your sourcefile, you can use it to split your raster file into
>> subimages.
>> http://www.gdal.org/gdal_utilities.html#gdal_translate
>> After that, you do use gdaltindex to create a tileindex. That part
>> is described in the raster howto:
>> http://mapserver.gis.umn.edu/doc44/raster-howto.html
>> Btw, what is the exact reason you want to split up your raster?
>> Performance?
>> Best regards,
>> Bart
>> Postbus 270
>> 2600 AG DELFT
>>>>> 11:39am >>>
>> Hi,
>> this subject is really not new. But I haven't found any real how-to
>> for the whole story. Perhaps somebody could clarify the steps needed.
>> when starting with an image of some larger size and when ending with
>> a tiled raster. Cause I guess that' what has to be done.
>> - At least I have now one single big raster. As far as I understood I
>> need to split the big image into smaller ones. But how?
>> - And then I can use gdaltindex to build the shapefile to define the
>> tiles. Right?
>> Thanks for clarification.
