Labeling of multi-polygon(?) states
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Tue Jul 12 09:44:08 EDT 2005
Jeff,
There is no automatic way that I know of, but to get the most control I
would create a point layer for the label points.
-Steve W.
Jeff de La Beaujardiere wrote:
> I am using the "statesp020" dataset from USGS National Atlas
> (http://edcftp.cr.usgs.gov/pub/data/nationalatlas/statesp020.tar.gz).
> When I ask Mapserver to draw labels, some states have a single label
> centered in the state (e.g., Alabama), while others have multiple labels
> around their edges (e.g., Florida). See, for example,
> http://map05.gsfc.nasa.gov/cgi-bin/modis?SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&LAYERS=states20m&STYLES=default&SRS=EPSG:4326&BBOX=-100.075,23.63125,-65.075,36.13125&WIDTH=700&HEIGHT=250&FORMAT=image/png
> I assume this is because states with complicated boundaries, such as
> along the coast, are built from several polygons, and each polygon is
> given a label. I can reduce the number of labels per state by setting
> MINDISTANCE, but I cannot get the labels of such states placed near the
> geographic center of the state--the label is always on the boundary
> (e.g., at the tip of the Florida keys).
> Is there a way to get better control of the label position, or to
> rebuild the shapefile in a way that perhaps produces a lower-res border
> but has better labeling?
> -Jeff DLB
