Res: [UMN_MAPSERVER-USERS] Res: Re: [UMN_MAPSERVER-USERS] Res:
Re: [UMN_MAPSERVER-USERS] PC256 color images (I need more quality)
Ezequias Rodrigues da Rocha
ezequias at RECIFE.PE.GOV.BR
Tue Jul 12 10:12:15 EDT 2005
I believe that Mapserver is not using GD could you tell me how to check it ?
Sincerely
Ezequias
-------Mensagem original-------
De: Ezequias Rodrigues da Rocha
Data: 07/12/05 10:31:54
Para: MAPSERVER-USERS at LISTS.UMN.EDU
Assunto: [UMN_MAPSERVER-USERS] Res: Re: [UMN_MAPSERVER-USERS] Res: Re:
Hello,
FORMATOPTION "QUALITY=100" does not make any difference.
Should I increase the quality more than 100 ?
Sincerely
Ezequias
De: Pericles S. Nacionales
Data: 07/11/05 19:13:16
Para: Ezequias Rodrigues da Rocha
Cc: MAPSERVER-USERS at lists.umn.edu
Assunto: Re: [UMN_MAPSERVER-USERS] Res: Re: [UMN_MAPSERVER-USERS] PC256
I guess I still don't know what your problem is. If you're talking about
quality in the sense of having compression artifacts, then you can add
something like FORMATOPTION "QUALITY=100" in your OUTPUTFORMAT. Or perhaps
you should be using PNG24 instead of JPEG. Read through
http://mapserver.gis.umn.edu/doc/mapfile-reference.html#outputformat for
more
output related info.
Also read http://mapserver.gis.umn.edu/doc/raster-howto.html for raster
input
stuff.
-Perry
On Monday 11 July 2005 13:36, Ezequias Rodrigues da Rocha wrote:
> I commented the lines and the image got worst.
> And now ?
> Data: 07/08/05 16:59:20
> Assunto: Re: [UMN_MAPSERVER-USERS] PC256 color images (I need more
quality)
> Ah, I should have looked further down on your message. Comment out the
> PROCESSING parameters and see what happens.
> -Perry
> On Friday 08 July 2005 15:07, Ezequias Rodrigues da Rocha wrote:
> > Good afternoon (for some of you)
> > I am trying to make Mapserver render a 24bits but it only send to me a
> > 256 colors image.
> > Here some of my Map file:
___________________________________________________________________________
> >__ ________________
> > fontset "/usr/java/jre1.5.0_01/lib/fonts/LucidaTypewriterRegular.ttf"
> > imagecolor 255 255 255
> > imagetype jpeg
> > shapepath "/var/www/cgi-bin/"
> > size 600 440
> > units meters
> > projection
> > "int=epsg:29185"
> > end
> > LAYER
> > NAME "Imagem56"
> > data "raster/recorte_56.tif"
> > STATUS off
> > TYPE RASTER
> > PROCESSING "DITHER=YES"
> > PROCESSING "BANDS=1,2,3"
> > PROCESSING "COLOR_MATCH_THRESHOLD=3"
> > END
> > OUTPUTFORMAT
> > NAME jpeg
> > DRIVER "GD/JPEG"
> > MIMETYPE "image/jpeg"
> > IMAGEMODE RGB
> > EXTENSION "jpg"
> > END
> > end # End Map
> > Best regards to all
> > Ezequias
> Conservation Biology Program
> University of Minnesota
> 1530 Cleveland Ave. N., 115GrnH
> St. Paul, MN 55108
St. Paul, MN 55108
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050712/37c92665/attachment.html
