Question re: PostGIS and MapScript getExtent() function
Steve Hall
steve.hall at MERCATORGEOSYSTEMS.CO.UK
Tue Jul 12 14:30:46 EDT 2005
Thanks Paul,
This all sounds very reasonable to me.... I'll keep this to myself for now
then.
I'm curious about the fact that this is implemented for Oracle which is
performing a very similar operation (i.e a spatial aggregate,
SDO_AGGR_MBR). Is Oracle more efficient than PostGIS in this area or is
there a difference in approach that i'm missing...?
For my two-pennorth a function like this is very useful, as it allows me to
change the filter for a layer, and alter the map extent to match the extent
of the "new" layer, without needing to do any "dirty" SQL on the back-end
database manually to find the new extent. Perhaps if it can't / shouldn't
be done via these msXXXLayerGetExtent() functions there is another way, or
could it be listed as an enhancement?
Thanks again, i'm new to the contributing side of Open Source so forgive my
early mistakes!
Steve
----- Original Message -----
To: "Steve Hall" <steve.hall at mercatorgeosystems.co.uk>
Cc: <MAPSERVER-USERS at LISTS.UMN.EDU>; <MAPSERVER-DEV at LISTS.UMN.EDU>
Sent: Tuesday, July 12, 2005 6:09 PM
Subject: Re: [UMN_MAPSERVER-USERS] Question re: PostGIS and MapScript
> Steve,
> If you grep through the source, you'll see the calls, which are mainly in
> the WMS code (pulling extents for capabilities). The problem is that the
> return time for the call can be very large for very large tables. Which
> is not really acceptable for a capabilities return. Maybe it is
> acceptable for your application. This is the real problem. We want
> something with very low return times (as a shapefile extents call is) but
> we cannot get it with the extent() function, because that requires a
> sequence scan.
> So basically, we cannot simply stick in your implementation, or we are
> building a big obscure "gotcha" into mapserver. ("Why does it take
> forever to return a capabilities file for my PostGIS backed WMS?
> Everything else is fast.")
> Perhaps the folks on -DEV can return some zen wisdom on the correct
> approach to this.
> Paul
> On 12-Jul-05, at 9:52 AM, Steve Hall wrote:
>> Hi Paul,
>> Exactly right - it definitely needs reviewing by those that know more
>> about MapServer internals than I do. (which is most of you I expect).
>> How is this function used my MapServer itself then? The context in
>> which I am using it is via an explicit $layerObj->getExtent() call from
>> PHP/MapScript, so in this respect the current implementation is not much
>> use, but I suspect there is more to this function than just an
>> implementation for this call. The main issue I had was that this
>> function worked as I expected for Oracle, yet not for PostGIS, meaning
>> I'd need some ugly code in my app to deal with the inconsistency...
>> Anyway, i've attached my version of the function for you to take a look
>> at. My implemenation is basically the version that was commented out,
>> with the compilcation errors & warning resolved, added support for the
>> FILTER expression and support for either BOX or BOX3D return clauses
>> from PostGIS extent().
>> Many thanks,
>> Steve
>> ----- Original Message ----- From: "Paul Ramsey"
>> <pramsey at refractions.net>
>> To: "Steve Hall" <steve.hall at MERCATORGEOSYSTEMS.CO.UK>
>> Sent: Tuesday, July 12, 2005 3:49 PM
>>> msPOSTGISLayerGetExtent() is potentially extremely inefficient,
>>> depending on how it is implemented, so I would have to see your patch
>>> to judge if it does more harm than good. It may be doing good things
>>> for you and bad things for others. One thing it *could* do without
>>> harm is read the wms_extent meta-parameter and use that if it is
>>> provided by the user. There are also a few version specific fast
>>> extent functions available in PostGIS, but they are not guaranteed to
>>> work in all cases, at all times, correctly.
>>> On 12-Jul-05, at 2:58 AM, Steve Hall wrote:
>>>> Hi All,
>>>> I'm using MapServer 4.6.0 with Oracle Spatial and PostGIS data
>>>> sources via PHP/MapScript. Part of my application code looks like
>>>> this pseudo-code :
>>>> $map->setLayerFilter("ThematicData", "REQUEST_ID=121");
>>>> $map->zoomToLayer("ThematicData");
>>>> Here i'm setting a specific FILTER expression for a layer, and then
>>>> zooming to the extent of the (now filtered) layer. I use the
>>>> layerObj->getExtent() and then mapObj->setExtent() functions to
>>>> achieve this behind the scenes. This works great for Oracle, the
>>>> query is fast and makes for nice, tidy code in my application without
>>>> the need for Oracle specific SQL statements to derive the new extent.
>>>> However when I try this on PostGIS I just get a massive (useless)
>>>> extent returned. Digging into the code I can see that the
>>>> msPOSTGISLayerGetExtent() function in mappostgis.c is effectively
>>>> doing nothing although a lot of code is commented out.
>>>> Working on my local code I have re-enabled this code, fixed the
>>>> compilation errors and changed it so that when a FILTER is applied to
>>>> the layer this is used as part of the SQL call to PG. It seems to
>>>> work great (from PHP/MapScript) and performance is fine and is really
>>>> useful for me meaning I don't need to calculate the extents for a map
>>>> myself - MapServer can supply the information in a generic and
>>>> abstract fashion.
>>>> Ideally I would like to get this code fed back into MapServer, but of
>>>> course only if it's acceptable to you all. So, should I instead
>>>> post this to mapserver-dev or can I pass on the new code to someone
>>>> from here?
>>>> There may be good, historical, reasons why this wasn't ever
>>>> implemented though so please let me know!
>>>> Many thanks,
>>>> Steve Hall
>>>> <msPOSTGISLayerGetExtent.c>
