place a point in the map
Fawcett, David
David.Fawcett at STATE.MN.US
Wed Jul 13 09:50:00 EDT 2005
Nuri,
What URL are you using to call your map? If it doesn't include '&layer=myvirtuallayer', you should set the LAYER STATUS to DEFAULT in the Map file.
Also, the layer name in your map file doesn't match the one in your ogrinfo output (mapa21). I realize that you may have renamed the layer, but make sure that the names match.
I also don't see a SYMBOLSET or FONTSET line in your map file to tell MapServer where to look for symbols or fonts.
David.
David Fawcett
Minnesota Office of Environmental Assistance
david.fawcett at moea.state.mn.us
651.215.0200
-----Original Message-----
Sent: Wednesday, July 13, 2005 3:58 AM
To: David.Fawcett at state.mn.us; MAPSERVER-USERS at lists.umn.edu
Subject: RE: [UMN_MAPSERVER-USERS] place a point in the map
Hi David,
I tested my application with an Access database.
It contains a table named taula
long lat
15 28
25 50
28 75
60 100
I created a DSN link named mapa21mdb
My mapa21.ovf file is:
<OGRVRTDataSource>
<OGRVRTLayer name="mapa21">
<SrcDataSource>ODBC:mapa21mdb</SrcDataSource>
<SrcLayer>taula</SrcLayer>
<GeometryField encoding="PointFromColumns" x="long" y="lat"/>
<GeometryType>wkbPoint</GeometryType>
</OGRVRTLayer>
</OGRVRTDataSource>
Then I tryed connection executing: ogrinfo
d:\webserver\mapserver2\mapa21.ovf -ro
and result was:
INFO: Open of `d:\webserver\mapserver2\mapa21.ovf'
using driver `VRT' successful.
1: mapa21 (Point)
Later I tried: ogrinfo d:\webserver\mapserver2\mapa21.ovf mapa21 -ro
and result was:
Layer name: mapa21
Geometry: Point
Feature Count: 4
Extent: (15.000000, 28.000000) - (60.000000, 100.000000)
Layer SRS WKT:
(unknown)
long: String (50.0)
lat: String (50.0)
OGRFeature(mapa21):0
long (String) = 15
lat (String) = 28
POINT (15 28)
OGRFeature(mapa21):1
long (String) = 25
lat (String) = 50
POINT (25 50)
OGRFeature(mapa21):2
long (String) = 38
lat (String) = 75
POINT (38 75)
OGRFeature(mapa21):3
long (String) = 60
lat (String) = 100
POINT (60 100)
Then I created my map:
MAP
IMAGETYPE PNG
EXTENT 15.000000 28.000000 60.000000 100.000000
SIZE 500 350
#SHAPEPATH "data"
IMAGECOLOR 255 180 0
# Start of LAYER DEFINITIONS ---------------------------------------------
LAYER
NAME "MyVirtualLayer"
TYPE POINT
CONNECTIONTYPE OGR
CONNECTION "mapa21.ovf"
DATA "taula" # the name of the OGRVrtLayer
STATUS ON
LABELITEM long #may need to use table.name or just name depending on
your OVF file.
PROJECTION
"init=epsg:4326"
END
CLASS
SYMBOL 1
SIZE 6
COLOR 255 0 0
LABEL
SIZE MEDIUM
TYPE BITMAP
COLOR 0 0 0
END
END
END
# End of LAYER DEFINITIONS -------------------------------
END # end of map file
The only thing that appears in the screen is a yellow rectangle, nothing
else. Could be the wrong extent values?
I thank you for your help.
Nuri
_________________________________________________________________
Moda para esta temporada. Ponte al día de todas las tendencias.
http://www.msn.es/Mujer/moda/default.asp
