Generating reference map image
Lluís Garcia i Mestres lluisgm at GMAIL.COM
Thu Jul 14 07:54:27 PDT 2005
 The way to get the reference is ok for me, I've done the same. You should
reduce the size of the image to the expected size of the reference, and
keeping the same proportion from your main map.
 As an example, my main map is 500x400 and the reference is 150x120 (3,333
less times the original size)
2005/7/14, Gambin Dejan <Dejan.Gambin at pula.hr>:
> Hi,
> I have a problem that my reference map position is not identical to the
> position on the main map. The difference is not big but I would like to
> know why. Adn I would like to know what is the best and simplest way to
> create the reference map image?
> I have created it as follows:
> 1. I opened my main map, selecting some layers I would like to be seen
> on the reference map (such as my city borders)
> 2. I have zoomed out to the full extent
> 3. I have copied this last created image from mapserver image folder
> (IMAGEPATH) to the folder where the reference map image resides and
> renamed it to the name of reference image. So I let the browser reduce
> the reference image size to that set in mapfile.
> Any suggestions?
> thanks
> dg
Lluís Garcia i Mestres,
lluisgm at gmail.com
lluisgm at hotmail.com
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050714/f34f3e78/attachment.htm>
More information about the MapServer-users mailing list
