Novice with Tutorial Question.
Fawcett, David
David.Fawcett at STATE.MN.US
Thu Jul 14 17:02:02 EDT 2005
As a layer in your map file, it could look like this:
LAYER
NAME landsat
STATUS DEFAULT
TYPE RASTER
CONNECTIONTYPE WMS
CONNECTION "http://wms.jpl.nasa.gov/wms.cgi?"
PROJECTION
"init=epsg:4326"
END
METADATA
"wms_name" "us_landsat_wgs84"
"wms_server_version" "1.1.1"
"wms_srs" "EPSG:4326"
"wms_format" "image/png"
END
END
David.
David Fawcett
Minnesota Office of Environmental Assistance
david.fawcett at moea.state.mn.us
651.215.0200
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]On
Behalf Of Pagurek,Debbie [NCR]
Sent: Thursday, July 14, 2005 3:18 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] Novice with Tutorial Question.
I guess they are in the process of updating the tutorial. But in order
to get something back from the service you tried to access - use the
following:
http://wms.jpl.nasa.gov/wms.cgi?REQUEST=GetMap&LAYERS=us_landsat_wgs84&S
TYLES=&FORMAT=image/png&TRANSPARENT=TRUE&srs=EPSG:4326&bbox=-180,-90,180
,90&width=600&height=300
I did a GetCapabilities request first:
http://wms.jpl.nasa.gov/wms.cgi?REQUEST=GetCapabilities
And that showed me that the layer names are different than expected.
Also - the request needed is request=GetMap, and this service seems to
require the other parameters listed here. I think this service also
requires case sensitivity?
Good luck,
D. Pagurek
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Jim Downing
Sent: Thursday, July 14, 2005 3:54 PM
Subject: [UMN_MAPSERVER-USERS] Novice with Tutorial Question.
This is my first exposure to Mapserver, and I'm working through the
tutorial.
I'm having a problem with Example1-6 which is meant to display data from
another WMS service.
The mapfile has a line:
CONNECTION
"http://wms.jpl.nasa.gov/wms.cgi?REQUEST=map&LAYERS=us_landsat7&STYLES=&
FORM
AT=png&TRANSPARENT=true"
which doesn't seem to do anything.
So I sent the request through the browser and got a response that
includes: <ServiceException>Unknown value for key
'request'</ServiceException>
I'm I doing something wrong here, or is there an error in thr tutorial?
I should probably be able to work this out for myself with some sort of
'discover' command, but I've not got that far yet.
Regards,
Jim Downing
WayTo Integration
Edmonton, Alberta
