Raster zoom problem with ERDAS Imagine Files
Frank Warmerdam
fwarmerdam at GMAIL.COM
Fri Jul 15 11:08:06 EDT 2005
On 7/14/05, Moen, Paul T. <pmoen at state.nd.us> wrote:
> I rebuild MapServer after every time I build and install a different GDAL.
> I tried your suggestions from the command line and "mapserv –v" gave me
> MapServer version 4.6.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
> SUPPORTS=WMS_CLIENT SUPPORTS=WFS_CLIENT INPUT=TIFF INPUT=EPPL7 INPUT=OGR
> INPUT=GDAL INPUT=SHAPEFILE
> But, shp2img doesn't produce any output it just hangs. The following is
> the terminal output.
> [swc2:/MapServerSource/src/mapserver-4.6.0] pmoen%
> ./shp2img -m
> /Applications/4DWebSTAR/WebServer/DefaultSite/mapfiles/test.map
> The command prompt never returns when running shp2img. The only way to get
> the command prompt back is to ctrl-c. If I try the GDAL 1.2.6 (non cvs
> version) shp2img works fine. It returns me to the command prompt
> immediately and exports the attached image. It is only with the cvs version
> that the problem occurs.
> test.map is a very simple mapfile with one layer, "North" which is a
> polygon of North Dakota.
Paul,
I'm afraid I don't know what is going wrong. If you are handy with a
debugger, then you could run shp2img, break it when it hangs, and
get a traceback with the "where" command.
Alternatively, if you are in a position to provide "ssh" access to your
machine, I could do some investigation.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
