problems with shapefile
Kralidis,Tom [Burlington]
Tom.Kralidis at EC.GC.CA
Mon Jul 18 18:28:35 EDT 2005
We're having some problems with some (what we think is) simple shapefile
polygon data.
ogrinfo -al <file>.shp works on the file. When I add to my .map file
and try to interact via OGC:WMS, the data does not display. When I do a
OGC:WMS GetCapabilities, the bounding coordinates per LatLonBoundingBox
are not reflective of the data extents.
When I try with shp2img, I get the following error:
$ shp2img -m config.map -all_debug 1 -l pda_al83_polygon2
Mon Jul 18 19:04:34 2005 - msSearchDiskTree(): Unable to access file.
Unable to open spatial index f or
/usr/local/wwwsites/apache/devgeo.cciw.ca/apps/mapserv/services/ecows/./
pyrtmp/pda_al83_polygon2.
qix. In most cases you can safely ignore this message, otherwise check
file names and permissions.
(Why is it looking for a .qix?)
When I generate the .qix with shptree and run shp2img again with the
same args, no error is given (although it provides debug info on a layer
I didn't ask for on the command line [all my LAYERs are STATUS ON).
To confirm, I am able to eyeball and query the data using uDig and
(sigh) ArcExplorer.
I'm using latest CVS. What gives?
Thanks
..Tom
