catch Query result - No matching record(s) found
Tyler Mitchell
tylermitchell at SHAW.CA
Mon Jul 18 18:57:59 EDT 2005
Hi David, There are templates you can provide in the WEB object, called EMPTY or ERROR.
See:
http://ms.gis.umn.edu/docs/reference/mapfile/web
Tyler
----- Original Message -----
Date: Monday, July 18, 2005 1:18 pm
Subject: [UMN_MAPSERVER-USERS] catch Query result - No matching record(s) found
> Hi Group,
> I was wondering if there is any flexability in what you can do
> with the
> output that is generated when a query results in no features found.
> Currently I get this type of output:
> <BODY BGCOLOR="#FFFFFF">
> msQueryByPoint(): Search returned no results. No matching
> record(s) found.
> <br>
> </BODY>
> Mapserver seems to completely ignore any of the defined templates
> if the
> users query returns no results. Is there another type of template
> thatcan be defined? I personally don't like this default output
> and would
> like to be able to customize it or be able to trap it and deal
> with it
> through code somehow. I'm currently not using mapscripts, only
> cgi and
> javascript, but am intrested in any solutions that one might have.
> Thanks,
> DaviD
