PHP MapScript / dynamic points from MySQL / possible to query?
Dylan Beaudette
dylan at IICI.NO-IP.ORG
Wed Jul 20 00:15:33 EDT 2005
Pete,
Are there any examples of this on the web? Also, is there any way to
use javascript to bring up information on features in the returned
images- i.e. with some sort of image map?
thanks!
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
On Jul 19, 2005, at 9:53 AM, Peter Giencke wrote:
> Jeff,
> One idea is by writing those points to a javascript array, you could
> implement a js function to access the array (via mouseclick or
> whatever) and
> present the data in any number of ways. You could keep your code
> relatively
> intact for this by having the php write all the javascript necessary
> for
> this.
> -pete
> Pete Giencke
> Data and Information Management
> Great Lakes Commission
> -----Original Message-----
> From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]
> On
> Behalf Of Geoff Rowland
> Sent: Tuesday, July 19, 2005 12:36 PM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: [UMN_MAPSERVER-USERS] PHP MapScript / dynamic points from
> MySQL /
> possible to query?
> I am pulling some lat/lon coordinates out of a database and drawing
> them on
> a map using code like this (not sure if this is really the best way,
> but
> it's the code I came up with, heh)
> $map= ms_newMapObj('world.map');
> $layer = $map->getLayerByName('alerts');
> for ($j=0; $j < mysql_num_rows($result); $j++)
> $row = mysql_fetch_assoc($result);
> ${$pt} = ms_newPointObj();
> ${$pt}->setXY($row[lat],$row[lon]);
> ${$pt}->draw($map, $layer, $img, 0 ,$row[location]);
> $url = $img->saveWebImage();
> works great. However I really want to make it so that when a user
> clicks on
> the point, information about the point will come up. I assume this is
> not
> possible with the way I currently have this setup, is that correct?
> What
> would be the best way to go about doing this?
> Cheers,
> Geoff
> Geoffrey Rowland
> Technical Officer
> Climate Information Project
> NOAA Research
> Office of Global Programs
> http://www.cip.noaa.gov
> http://www.ranetproject.net
> Contractor,
> RGII Technologies, Inc., a Computer Horizons Company http://www.rg2.com
> Phone: 301-427-2344
> Fax : 301-427-2082
> geoffrey.rowland at noaa.gov
