postgis
Jachym Cepicky
jachym.cepicky at CENTRUM.CZ
Thu Jul 21 04:34:48 EDT 2005
Hallo,
I have following problem with mapserver: I can not load vector file
stored in postgis.
I use Debain (testing), with mapserver from official repository and
postgis from the Debian-Gis project
(http://pkg-grass.alioth.debian.org/cgi-bin/wiki.pl).
I stored vector shape file with help of shp2pgsql apparently without
problems. I can acces the file e.g. usin Qgis and I can load it to
GRASS GIS.
However mapserver gives me quite long report, about that he is not able
to display the map.
msDrawMap(): Image handling error. Failed to draw layer named 'obrys'.
prep_DB(): Query error. Error executing POSTGIS DECLARE (the actual query) statement: 'DECLARE mycursor BINARY CURSOR FOR SELECT kod::text,popis::text,asbinary(force_collection(force_2d()),'NDR'),OID::text from WHERE && setSRID('BOX3D(-599514.328920447 -1159983.83918495,-581875.449556553 -1142344.95982105)'::BOX3D, find_srid('','','') )'
Postgresql reports the error as 'ERROR: syntax error at or near "WHERE" at character 126 '
(I posted the whole file to http://les-ejk.cz/tmp/mapserver.html)
The mapfile part for the layer follows:
LAYER
NAME obrys
TYPE polygon
METADATA
"title" "LH SLP Krtiny"
END
CONNECTIONTYPE POSTGIS
CONNECTION "host=10.0.0.24 dbname=krtiny user=jachym"
DATA "the_geom FROM obrys"
CLASSITEM kod
LABELITEM popis
MINSCALE 50000
CLASS
EXPRESSION '1'
NAME 'PUPFL "SLP Krtiny"'
COLOR 49 135 32
END
CLASS
EXPRESSION '2'
NAME 'Sidlo'
COLOR 190 190 190
LABEL
TYPE truetype
FONT arialce
SIZE 7
COLOR 0 0 0
BACKGROUNDCOLOR 255 255 255
END
END
END
In /etc/postgresql/pg_hba.conf is:
host krtiny jachym 10.0.0.24 255.255.255.0 trust
What to do?
Thank you
Jachym
Jachym Cepicky
e-mail: jachym.cepicky at centrum.cz
URL: http://les-ejk.cz
GPG: http://les-ejk.cz/gnupg_public_key/
