Virtual Spatial Data and MySQL client
Bart van den Eijnden
BEN at SYNCERA-ITSOLUTIONS.NL
Fri Jul 22 07:16:36 EDT 2005
Frank,
I have tracked down the issue by looking at the source code.
There was a problem with my MYSQL connect statement, now I use the following which works, note the name of the schema in front of the connect string, this seems to make the big difference:
<SrcDataSource>MYSQL:westholland,user=root,password=psv9570,port=3306,tables=bedrijven</SrcDataSource>
I think an example would help on the MySQL driver page :-) :
http://www.gdal.org/ogr/drv_mysql.html
D:\ms4w\apps\stragisweb\htdocs\sites\mdwh\data>ogrinfo bedrijven_mysqlclient.ovf
ERROR 4: Update access not supported for VRT datasources.
user=root, password=16254705
Had to open data source read-only.
INFO: Open of `bedrijven_mysqlclient.ovf'
using driver `VRT' successful.
1: bedrijven (Point)
Best regards,
Bart
Syncera IT Solutions
Postbus 270
2600 AG DELFT
tel.nr.: 015-7512436
email: BEN at Syncera-ITSolutions.nl
>>> Bart van den Eijnden <BEN at SYNCERA-ITSOLUTIONS.NL> 07/22/05 09:35am >>>
Hi Frank,
I added the debug statement and the user is empty. Btw, on another note, how can one specify the schema to be used, or does one just prepend it to the tablename?
user=, password=16253249
ERROR 1: MySQL connect failed for: user=root,password=psv9570,port=3306
Access denied for user 'BEN'@'localhost' (using password: YES)
FAILURE:
Unable to open datasource `bedrijven_mysqlclient.ovf' with the following drivers
-> ESRI Shapefile
-> UK .NTF
-> SDTS
-> TIGER
-> S57
-> MapInfo File
-> DGN
-> VRT
-> AVCBin
-> REC
-> Memory
-> CSV
-> GML
-> ODBC
-> MySQL
-> OCI
Ovf file used:
<OGRVRTDataSource>
<OGRVRTLayer name="bedrijven">
<SrcDataSource>MYSQL:user=root,password=psv9570,port=3306</SrcDataSource>
<SrcLayer>bedrijven</SrcLayer>
<GeometryType>wkbPoint</GeometryType>
<LayerSRS>epsg:28992</LayerSRS>
<GeometryField encoding="PointFromColumns" x="LCO_XCOORDINAAT" y="LCO_YCOORDINAAT"/>
</OGRVRTLayer>
</OGRVRTDataSource>
Best regards,
Bart
Postbus 270
2600 AG DELFT
>>> Frank Warmerdam <fwarmerdam at GMAIL.COM> 07/21/05 06:56pm >>>
On 7/21/05, Bart van den Eijnden <BEN at syncera-itsolutions.nl> wrote:
> Hi list,
> I can't connect to a MySQL database using the MySQL client in OGR. I am using MySQL client 4.1 on a 4.1 localhost database. It works fine through ODBC.
> It looks like GDAL/OGR is trying to log in with a different user than I specify, the Windows user logged on to the computer, how come?
> I get the following:
> Warning 1: 'database=westholland' in MYSQL datasource definition not recognised
> and ignored.
> ERROR 1: MySQL connect failed for: user=root,password=psv9570,port=3306,database
> =westholland
> FAILURE:
Bart,
Sorry, I don't know why that isn't working. As I read the code, it
should have passed in root as the userid. In the module:
gdal/ogr/ogrsf_frmts/mysql/ogrmysqldatasource.cpp
there is a call like:
if( hConn
&& mysql_real_connect( hConn,
oHost.length() ? oHost.c_str() : NULL,
oUser.length() ? oUser.c_str() : NULL,
oPassword.length() ? oPassword.c_str() : NULL,
oDB.length() ? oDB.c_str() : NULL,
nPort, NULL, 0 ) == NULL )
CPLError( CE_Failure, CPLE_AppDefined,
"MySQL connect failed for: %s\n%s",
pszNewName + 6, mysql_error( hConn ) );
mysql_close( hConn );
hConn = NULL;
My suggestion is that you add a printf() to report the actual arguments
being passed to this functions for debugging purposes.
eg.
printf( "user=%s, password=%d\n", oUser.c_str(), oPassword.c_str() );
If the user reported by this is root then it is something funky deep
inside the mysql API. If it is "BEN" or an empty string then we know
that something is going wrong in the parsing logic for the datasource
name (which you can follow up with me).
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
