database connection
Bart van den Eijnden
bartvde at XS4ALL.NL
Fri Jul 22 14:28:40 EDT 2005
Hi Martin,
You probably can if it is supported by OGR, it includes ODBC support and
direct MySQL support for your list of databases, I think you can store the
geometry in WKT format and use what is called virtual spatial data.
http://www.gdal.org/ogr/ogr_formats.html
http://www.gdal.org/ogr/drv_vrt.html
Best regards,
Bart
On Fri, 22 Jul 2005 18:26:37 +0200, Martin Poggensee <info at POGGENSEE.NET>
wrote:
> Is it possible to connect any database which supports the OGC standard
> with
> the mapserver ??? I need to visualize geeometric data from different
> database systems (Sybase, MS SQL Server, mySQL, etc.).
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
