client side image map: classitem
Bob Bruce
covariance at SHAW.CA
Fri Jul 22 15:48:50 EDT 2005
Dylan:
I just had a look at your page that was in your post and the map
looks just fine. The <map has all of the areas labeled with their names and
clicking on the areas does the alert with the name. What is the problem?
Bob Bruce, Winnipeg, Manitoba
http://www.hwps.ca
On Thu, 21 Jul 2005 15:53:05 -0700, Dylan Beaudette <dylan at IICI.NO-IP.ORG>
wrote:
>Greetings,
>I have recently set up a working version of the image map example provided on
>the mapserver wiki here:
>http://169.237.35.250/~dylan/mapserver/dhtml/image_map_test.php
>However, the polygons are labeled as 0,1,2,3 ... is there some way for the
>image map to be constructed using an attribute in the original data source?
>Per Jim Donaghy's suggestion, I have tried adding CLASSITEM "NAME" to my
>mapfile, but it does not seem to affect the resulting image map...
>any ideas?
>Dylan Beaudette
>Soils and Biogeochemistry Graduate Group
>University of California at Davis
>530.754.7341
Dylan:
